However, I'm still concerned about the transmission leaking after a long city drive. Even with my temperature gauge being in the wrong spot, when it reads "hot" at around 200+, the transmission will begin to leak.
I've noticed the leak around the pan gasket usually, so I probably just need to tighten it up a little bit.
Once, I saw it leaking from the cover plate under the bell housing. Whether that is the front seal or the top vent leaking down, I'm not sure. I was relating this to the fluid level, because maybe I've had it too full, or not full enough.
