Electrical Gremlin
Old Jul 15, 2019 | 11:29 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Electrical Gremlin
Drove the truck a couple hundred miles over the past few days only to have it misbehave 30 miles from home.
All the sudden, without warning, the engine sounded like I pulled the choke bout too far. An immediate scan of the cluster showed the amp meter at Max discharge. I limped sputtering a 1/2 mile to an intersection with a gas station and immediately popped the hood. Nothing obvious. I disconnected the positive ground battery cable which was sparking as I did so indicating a nice big load (presumably a short).
Now for the questions - why would a short cause the engine to behave poorly?
Any place to look first for such a short (generator, voltage regulator)?
Vehicle is fused and has stock breaker. None blew or tripped.
This is a stock F6 with 239 V8.
Old Jul 15, 2019 | 11:40 AM
Moe Craig's Avatar
Moe Craig
If it's grounding enough to starve the engine of electrical power it will run poorly!
Old Jul 15, 2019 | 12:18 PM
Mixer man's Avatar
Mixer man
If it's not tripping breakers or blowing fuses the problem is upstream of those. I suspect a wiring short and/or a defective voltage regulator/generator. The fact that you are getting a heavy discharge suggests that your ground connections are good. Test the voltage at the coil.
Old Jul 15, 2019 | 12:23 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Check the wire going thru the ammeter loop for shorts. I would expect you'd smell or see smoke tho. Check all the connections on the circuit breakers, too.
daben48
Oct 16, 2010 08:33 AM
RangerTuff05
Dec 30, 2008 01:29 AM
chicowoodhill
Dec 5, 2006 11:40 AM
snowmobiel0507
Electrical Systems/Wiring
Sep 26, 2005 04:22 PM
Kirkus05
Dec 12, 2004 05:41 PM
