Tail-lights not working
Old Oct 5, 2003 | 09:40 PM
anotherF150's Avatar
anotherF150
I have a 71 F250 and I have no power going through the wires for the TAIL-LIGHTS.
I have checked the fuses, broke wires and switches. I cant find the problem so I am going to wire it all up new. Does any one have a diagram or know how to describe it to a person suck as I? I would appreciate it greatly.
Title edited to Reflect the actual topic by FTE Admin.
Old Oct 6, 2003 | 01:28 PM
Franklin2's Avatar
Franklin2
The whole truck is dead? Nothing works at all?
Old Oct 7, 2003 | 02:26 AM
anotherF150
no, just the wiring for the tail lights, I get no power to any thing after the fire wall.
Old Oct 7, 2003 | 08:55 AM
GeneStoner's Avatar
GeneStoner
Battery is charged, right???
Old Oct 9, 2003 | 02:00 AM
anotherF150
Truck runs.
Old Oct 10, 2003 | 05:27 AM
macguyver's Avatar
macguyver
Is the problem confined to the taillights meaning running lights or are the turn signals and brake lights affected as well? Are the front marker and turn signals working?
We need more info to track down the problem.
Old Oct 15, 2003 | 12:02 AM
anotherF150
Front blinkers have never worked, tail lights work, blinkers use to work along with the brake light, now I have no power from the blinkers or the brake light but I have power th them though.
Old Oct 15, 2003 | 12:29 AM
ZombieSlayer's Avatar
ZombieSlayer
In your first post you said you have no power to the tail lights. In your last post you say that the tail lights work
Old Oct 15, 2003 | 05:07 AM
macguyver's Avatar
macguyver
I'm still confused...
Is there power at the socket or not? Are the bulbs good? Is there power on both sides of all the fuses? Do the 4-way flashers do anything? If there's power at the socket and the bulb is good, it should light unless the ground is bad, either where the wire connects to the body or in the socket itself. Both are common problems.
Old Oct 15, 2003 | 04:48 PM
anotherF150
They did work (power to and from the blinker and brake light switches but not threw the threw the cab or wiring harnes). They dont work now.
Old Oct 16, 2003 | 05:05 AM
macguyver's Avatar
macguyver
You'll have to start at one end with a test light and try to determine where the problem is. A wiring diagram to follow would help a lot. If the turn signal switch is working, I'd start there.
Billyclub
Mar 23, 2017 09:12 AM
PRIMERED79 SHORT BED
Jul 10, 2016 07:45 PM
blurry
Oct 2, 2015 06:41 PM
Deacon_G
Sep 28, 2011 05:06 PM
broncobob50
1978 - 1996 Big Bronco
Oct 14, 2006 11:48 AM
