Electrical Help.
Old Jul 8, 2016 | 11:59 PM
PRIMERED79 SHORT BED's Avatar
Electrical Help.
1992 f150 302 4wd zf5
Having an issue with power bleeding into my rear turn signals.
I have some leds tail and i noticed the other day while my truck was parked idling that i have a faint glow to my taillights, so I tested the wires and sure enough i have power running back there and not sure why.
Things to note, abs light is on, and just noticed the other day my cruise isn't working anymore, could this all be related?
I tested the fuses and noticed when I pull fuse 18, the power to the taillights go out. But that fuse is labeled for speedometer.
So far everything works fine in the dash and signals, lights etc.
Not real good with electrical circuits, so can anybody help me out?
Thanks.
Old Jul 9, 2016 | 09:27 PM
Searched and found out how to pull abs codes, grounded the test lead and got a code 11.
Going to search that code.
Anybody have any ideas?
Old Jul 9, 2016 | 09:51 PM
eakermeld's Avatar
eakermeld
Very common problem with LED tail lights. You need to go get the resistors that are made to go with these types of LED lights and install them in-line and your problems will all disappear. If you had an E4OD trans instead of a stick it would be shifting really weird also.
Old Jul 9, 2016 | 11:10 PM
Found this.
1983 Ford Bronco Brakes & Hubs picture | SuperMotors.net
Stoplamp switch, is it talking about the switch on the brake pedal?
Old Jul 9, 2016 | 11:12 PM
Just the other day I installed one of those led flashers and still the same thing.
How do I install a resistor? The lights I have plug into the factory light socket.
Old Jul 10, 2016 | 01:11 AM
raystankewitz's Avatar
raystankewitz
Hmm . . .
Here is one in parallel with the filament;
http://www.xkglow.com/v/vspfiles/***...ing%20copy.jpg
This one is wired across the brake light wire and the ground wire in that socket.
Last edited by raystankewitz; Jul 10, 2016 at 01:15 AM. Reason: Fixing my poorly formed instructions. Gah!
Old Jul 10, 2016 | 06:25 PM
Thanks for the tip, I installed a resistor on each tail and sure enough the faint taillight went out and the abs light went out and my cruise is working once again.
Old Jul 10, 2016 | 07:15 PM
eakermeld's Avatar
eakermeld
Glad you got it fixed. You got any pics of the lights? Always like to look at cool new stuff.
Old Jul 10, 2016 | 07:45 PM
mike L
Sep 15, 2014 03:23 PM
coollooking96F350
Aug 26, 2012 08:18 AM
gspman
Electrical Systems/Wiring
Dec 11, 2003 07:23 AM
