78 F100 ignition issue??
Old Jul 13, 2019 | 09:27 AM
Piston Honda's Avatar
Piston Honda
I was driving home the other day from work when all of a sudden the truck spuddered a bit and the motor just quit. The truck is a 78 F100, 351M. I pulled the top of the air cleaner housing and seen that we are getting fuel so I assume it is the ignition system. I’m very inexperienced with the ignition system and don’t really know where to start the trouble shooting. I’ve tried looking at some threads on these types of issues but they either go off topic rather quickly or the problem was found and the thread ends. If anyone could help me diagnose this problem I’d appreciate it thanks.
Old Jul 13, 2019 | 10:08 AM
beartracks's Avatar
beartracks
If you are running the original Ford ignition that is probably your problem.
Old Jul 13, 2019 | 10:21 AM
Piston Honda
Never had a problem with it before. Do you mean that the factory ignition system is not sufficient? I know that the ignition modules are known to fail at some point or another, but other than that I thought the duraspark ignition systems were pretty dependable.
Old Jul 13, 2019 | 10:49 AM
beartracks's Avatar
beartracks
They seem to have problems as they age judging from this forum. Try to set the coil wire next to ground and crank it over to see if you get spark.
Old Jul 13, 2019 | 11:06 AM
Piston Honda
I’ve got spark at the end of the coil wire.
denny7170
Nov 16, 2016 08:20 AM
1joshie1
Mar 5, 2011 05:44 PM
Greywolfnsl
Apr 27, 2010 11:36 PM
95fordbronco302
1978 - 1996 Big Bronco
Apr 2, 2002 04:17 PM
FordBoy77
Mar 22, 2000 08:00 PM
