Sponsored by: Real Truck
**** power fail
Old Jul 11, 2019 | 08:59 PM
Drh33's Avatar
Drh33
**** power fail
The code reader said that the duck had low voltage so I tested it vagaries the battery and batteries read great still no power to the ficm. The truck is a 2004 f250 can someone please send a pic of the fuse box’s plz and help me fix it
Old Jul 12, 2019 | 09:21 AM
redfishtd's Avatar
redfishtd
Don't have your fuse box pic . It varies from year, don't want to give you bad info .Just check every fuse carefully to not mix them up . Take pic of fuses before moving them . Someone on here may have a book for your model year . You have a pcm relay that could be bad . You may have to get a haynes manual for your year or a mech shop may print one out for you on your fuse box . If it keeps blowing you will need diagrams .
Old Jul 13, 2019 | 02:49 AM
JKBrad's Avatar
JKBrad
Welcome to FTE Drh33! I moved your post to the Super Duty forum that cooresponds to your 2004 F250. Hopefully you will find the help you need from a great bunch of guys.
TheRifleman
Electrical Systems/Wiring
Jan 20, 2014 01:34 AM
2 cowpokes
Oct 15, 2013 05:33 AM
finerhomes
Sep 6, 2012 08:34 AM
23larry24
18
Oct 19, 2008 08:56 PM
english guy
Bronco II
Sep 8, 2003 11:24 PM
