Door speakers while Jimmi Jamming?
Old Jul 10, 2019 | 08:31 AM
tdc_worm's Avatar
tdc_worm
I know this has been beat to death ad nauseum, but the more i search and read, the more i confuse myself.
2017 Platinum with the Sony system.
The truck was broken into...access was gained by twisting the driver door lock cylinder with a pair of channel lock pliers. As such, I have to replace the driver's door handle and I am installing Jimmi Jammers and eliminating the lock cylinder.
So, while I am in there, would it be worth replacing the stock door door speakers with a 6x9 2 way component system? Would it be best to just plug and play the speakers while using the OEM resistor for the tweeters? I was thinking of going this route:
https://www.infinityspeakers.com/sal...GLOBAL-Current
Old Jul 10, 2019 | 10:57 AM
wicked 2018's Avatar
wicked 2018
These have been recommended several times - more expensive than most but most the sound comes from these speakers so its a good investment:
Amazon Amazon
Old Jul 10, 2019 | 03:05 PM
tdc_worm's Avatar
tdc_worm
https://www.amazon.com/gp/product/B072MLPGP1
thanks for the recommendation....not going to creep into the $500 range...just toying with the idea out of convenience.
Would you say that it is
a) is worth
b) plausible without installing the aftermarket crossover
Old Jul 10, 2019 | 03:08 PM
wicked 2018
a) is worth
I have not changed mine. This is based off of recommendations I have seen here and that kit comes with tweeters.
Where is @Tricon when you need him - he has done a lot of audio stuff.
Old Jul 11, 2019 | 02:58 PM
tdc_worm's Avatar
tdc_worm
I think I remembered reading him saying it was a reasonable approach, but I've slept since then...
ponyboy96
Feb 24, 2023 01:42 AM
ArrizX
2009 - 2014 F150
30
Aug 11, 2015 05:03 PM
Casey02L
Dec 28, 2005 11:45 AM
bn
1978 - 1996 Big Bronco
Jan 14, 2002 06:40 AM
