Remove dually center cap tool
Old Jul 9, 2019 | 08:09 AM
BocaIvan's Avatar
BocaIvan
Any tips on getting the caps back on, specifically on the SRW trucks?
I tried to put one on at the dealer that I found on the floor, and could not get it to go back on for the 5 mins I was trying.
Old Jul 9, 2019 | 01:38 PM
StonedGrey's Avatar
StonedGrey
Its a possibility that the metal clips in the center cap have moved to a position that wont allow the cap to clip all the way onto the lug nuts.
The metal clips in the center cap have to be aligned in each hole properly or it will never snap on the wheel properly. PITA.
Old Jul 9, 2019 | 03:14 PM
951 DAN's Avatar
951 DAN
Originally Posted by StonedGrey
Very nice. And thank you for the pics.
I use a ratchet strap & the lug bar. Its a little safer for not slipping and scratching the center caps.
Same here, strap and a short 2x4.
Old Jul 9, 2019 | 03:33 PM
2019er's Avatar
2019er
So I didn't RTFM yet. Are we saying that Ford has left us high and dry if we get a flat on the road using provided tools? That would have sucked out in 400 miles of nothingness on Nevada 50 and no signal in many places. And no traffic for hours at a time to boot.
Old Jul 9, 2019 | 03:54 PM
StonedGrey's Avatar
StonedGrey
Yes. Theres no way to take the rear center caps off a new dually with the provided equipment from Ford. Completely high & dry.
Keep a ratchet strap under the rear seat. Make sure the hooks on the ratchet straps have the proper curve to the hooks so they fit into the center cap slots. Some strap hooks fit, others do not.
Old Jul 17, 2019 | 11:47 AM
lovetorv's Avatar
lovetorv
I built a very similar tool as the OP except I screwed a wooden handle on one end of it and now I am able to pull the caps off by hand and not use the other tools from the toolkit as is being demonstrated here. I just keep my center cap removal tool under a rear seat vs wrapping it into the tool kit.
skidoorulz
21
Jul 21, 2018 09:43 AM
brandon_0384
Mar 19, 2017 11:26 AM
Watcher58
Feb 24, 2016 09:57 AM
NW 150
Jul 25, 2011 05:21 AM
79-400-POWER
Offroad & 4x4
Apr 8, 2008 08:29 PM
