Sorry Guys Another Spring Question...
Old Jul 7, 2019 | 09:46 PM
dzldenny's Avatar
dzldenny
Okay, so last fall we purchased a 2002 Ex 7.3 4x4 that came with a Cali style lift. 8+ up front 7 out back sitting on 37's. Not my style and a bit much for the short wheelbase that the Mrs has. Our 2000 sat on 35's with a 4 inch pro comp lift and we had a bit of rubbing so for this one I put together a 5 inch lift and plan on using the 35's. Its a combo of 5 inch springs up front from Superlift and the rear leafs it came with sitting on stock blocks out back. I took the double stacked 2 inch blocks out of the rears that it came with. The truck now sits at 29 1/2 up front and 28 1/2 in the rear.
My choices are to remove the stock blocks in the rear and build replacements to level me out, or just add the lower leaf and bump stop from a stock Ex rear pack and hope the front settles in after a few miles. I've searched for days on FTE and Googled as well. I can find the entire leaf pack or I can find the replacement bumpers but I can not find just the lower leaf. Anyone have a part number for me? Opinions on if this will work or if I should build the blocks? How much can I look for the fronts to settle after driving?
I'm not interested in bags. I do all of the heavy towing with the F350 and brackets and fittings just don't last the winters with the salt around here. When we broke leaves on the 2000 Pro Comp would not even replace them because they were too rusty to identify. I would rather have it a bit lower in the the front than go higher in the rear but I'm tired of the rubbing.
Thoughts on a fix for where I'm at now? Thanks in advance all...
Old Jul 7, 2019 | 10:23 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Superduty has 4" blocks
maybe pick one of those up? In the Tech section there is a discussion about the 4" flat block vs 4" angled block. I can't remember which is better for an Excursion. It affects the pinion angle and can cause driveline vibration. Wish I could tell you which one is preferred.
but with my money, I'd snag some 4" OEM blocks and call it a day. Especially if you like the ride with your current setup. If you cannot find OEM, steel blocks are pretty cheap on eBay.
rockhounds4x4
Apr 14, 2016 05:34 PM
jtapal
20
Jan 7, 2016 10:24 PM
Blown 331
Apr 26, 2013 10:45 AM
Dr. Johnson
Jul 13, 2012 06:23 PM
spartan
Feb 26, 2004 06:40 AM
