Sponsored by: Auxito
Code reader wont pull codes
Old Jul 6, 2019 | 08:28 PM
Charles46's Avatar
Charles46
My 2003 f150 with a 4.6 wont light up the code reader and ive tried 2 different ones.Then i tried the trip reset by holding it and none of the codes i see aren't listed
Old Jul 6, 2019 | 10:43 PM
steve(ill)'s Avatar
steve(ill)
there is a fuses that also controls the cigarette lighter ( and the code plug power)............. look in the operators book for which fuse is blown.
Old Jul 7, 2019 | 12:39 AM
Bluegrass 7's Avatar
Bluegrass 7
What you see from the Dash is in position just before 'GAGE'.
It was reserved for codes PA to PEx.
The 255 you see is a fill code and is an Octal number that would have been converted to Decimal to be more understandable, if it were used.
Example the FUEL position.
A ...54 would represent a low fuel level. A .178 would represent the 3/4 fuel level etc. in an Octal number base of 0 to 255.
You would need a Doc to interpret the dash data.
Check the fuse and DLC socket pin 16 for battery and 4, 5 for ground..
Good luck.
Old Jul 7, 2019 | 08:24 AM
Charles46's Avatar
Charles46
My cigarette lighter on the left works and changed the one on the right.The code reader works and i got a code of p302 but the Triton has a bad problem of spark plugs breaking off and Orileys sells a kit to remove them but im not doing it
Old Jul 7, 2019 | 11:42 AM
steve(ill)'s Avatar
steve(ill)
The 4.6 motor in your year range has NO bad problem of spark plug breaking... That is bad information... You can change them out in an hour.
Old Jul 7, 2019 | 01:09 PM
Sam I Am's Avatar
Sam I Am
Steve is 100% correct as usual.
The only spark plug problem on your truck is that you haven't changed them yet.
Mbizzal
16
Aug 13, 2015 07:11 AM
traxx808
May 2, 2011 07:30 AM
BigRy
Apr 23, 2010 07:28 PM
Johnny Bravo 45
Jan 8, 2010 10:53 AM
SICKANDTWYSTED
1997 - 2003 F150
Jan 14, 2008 06:42 PM
