Problems okay Two codes popped up numbers for six cylinder bad coil and spark plug bad 17730 miles plugs where change 4000 miles ago and I put new coil on 6, 550 miles Help!!! Please thank you in advance
give the actual code numbers... not an opinion of what is wrong... What motor do you have , 5.4 or 4.6 ? Did you use MOTORCRAFT plug or other ? ......Water / antifreeze can get into a spark plug hole and short the coil to ground... Pressure wash or heavy rain lately ?
