LED headlights
Old Jul 5, 2019 | 11:24 AM
Lrrr-RulerOfOmicronP's Avatar
LED headlights
Does anyone have experience and pics of 7" headlight conversion to H4 or LED? I plan on driving the wheels off my truck once it is done and want good headlights.
I have read the truck-lite LEDs are some of the best on a budget (300ish) but I don't know if I will like the way they look on the truck.
The h4 Hellas look good but I have read they are really not a lot better than seal beams. I guess they were pretty much designed in the 70s for European market.
Old Jul 5, 2019 | 05:29 PM
Jim-Pro's Avatar
Jim-Pro
Hello, I have the Truck Lite LED's installed on my 68 f 100. They plug in easy and fit the stock locations no problem. They work great, how ever they do not have a classic look to them. They are flat ish on the ext. profile. They are made from some kind of poly/ lexan lens so they look different than traditional sealed beams. I used to not want to drive my truck at night but not any more! They really do work well. I would recommend them to any one who wants see better at night.
More info can be found here on this thread: Got my TruckLite LED headlights! - The FORDification.com Forums
Hope this helps you out some, JIM
Old Jul 5, 2019 | 06:16 PM
Jim-Pro's Avatar
Jim-Pro
Here are some pics
low beam
high beam
Old Jul 5, 2019 | 06:34 PM
john jamieson's Avatar
john jamieson
If you're truck doesn't have it, I would recommend a relay harness so that your headlights get power from the battery and not through the switch. It made a big difference in my '66
john
Old Jul 5, 2019 | 10:05 PM
Your truck looks great with the lights! So some images online look like the lenses are smoke/tinted and some look clear. Your look tinted in the pics but that may just be lighting. My truck it a lighter color so I think a tinted lens would really stand out. Do they look tinted in person?
john
I am rewiring the truck and will probably do that also. It could be necessary if I run a high powers non-led headlight.
Thanks for information Jim and John!
Old Jul 6, 2019 | 06:52 AM
Jim-Pro's Avatar
Jim-Pro
The lenses are clear. Here is a review from a youtube video, shows some details.....https://www.youtube.com/watch?v=syCR...ature=youtu.be
I also did the relay up grade on the head light wiring. Don't know if it made them work any better but it is worth doing I believe .
Old Jul 6, 2019 | 07:07 AM
badboogernx's Avatar
badboogernx
vintagecarleds.com
Old Jul 6, 2019 | 11:23 AM
Originally Posted by badboogernx
vintagecarleds.com
I like the idea of Hella housings with LED bulbs but have to see if I can fit them and worry about not being Dot approved since there are no leds approved for halogen replacements in the US. I guess the EU is ok with it though.
I think if I go led sealed beam I will get the truck-lite or the United Pacific lights. Both look like they work really well. Thanks for the feedback!
Old Jul 6, 2019 | 02:15 PM
Jim-Pro's Avatar
Jim-Pro
Truck Lite is made in usa!
Old Jul 8, 2019 | 08:03 PM
old28's Avatar
old28
I like the Hella EU lens as they look like stock seal beams. I am running Hella 85/100 bulbs, not for everyone, don't use high beam if other cars are around, you need to set low beam so they are straight ahead or off to the right a little. They are on my 1971 F250, I'm in Southern, CA and have been running them for a year with no problem. I have a buddy in Northern, CA with the same setup & results.
If you live in a state that does vehicle inspection before Licensing not the way to go. I also installed a wiring harness and it helps a lot not running the full 12 volts through the headlight switch. It even helped my stock seal beams, just not what I was looking for.
ExPACamper
Apr 6, 2016 10:37 PM
kbarbee95
27
Mar 30, 2016 06:00 PM
InvincxbleDan
50
Jul 13, 2014 09:07 AM
DirtDiver
2009 - 2014 F150
Mar 5, 2012 10:58 PM
optikal illushun
Jun 22, 2009 12:41 AM
