Head studs
Old Jun 30, 2019 | 03:09 PM
Justmers60's Avatar
Justmers60
Head studs
Installed head studs gaskets heads rocker arms turn motor over by hand before installing valve covers turns easy and right before it makes a complete round it stops
Old Jun 30, 2019 | 03:15 PM
TooManyToys.'s Avatar
TooManyToys.
Did you make sure all the pushrods had a spring to them when set into the lifters?
Head work done?
Old Jun 30, 2019 | 09:26 PM
87crewdually's Avatar
87crewdually
Will it turn back? Is there a chance hardware fell in the intake? You could figure out what cylinder is coming up and inspect the cylinder through the glowplug hole with a borescope if you suspect something like a nut fell inside.
Ranger GT2
19
Feb 13, 2021 08:46 PM
Blackwaterforge
Aug 20, 2010 09:20 AM
1984F-150_351HO
Mar 23, 2010 01:41 PM
mooktank
Jul 11, 2004 02:30 PM
broncr
Nov 11, 2003 12:25 PM
