Modular V10 (6.8l)
Oil cooler torque spec
Old Jun 30, 2019 | 08:58 AM
alollich's Avatar
alollich
Hello,
Does anyone know the torque spec for the oil cooler stud/bolt on the V10?
I am replacing mine with a new Ford oil cooler as I have a small leak inside the cooler mixing oil and coolant I have seen a spec of 41-44 ft lbs but that seems a bit high? I know that the gasket surface should be dry when the new cooler is installed. Any other things to keep in mind when replacing the cooler?
Thank you
Old Jun 30, 2019 | 03:40 PM
alollich's Avatar
alollich
Looks like there was a recall on the oil cooler many years ago. The torque spec is listed in the repair section....42 lb-ft.
http://ww2.justanswer.com/uploads/he...oil_cooler.pdf
navistarnut
Mar 25, 2022 07:10 AM
2006fordf25060
May 2, 2018 06:40 PM
DavidLM11
Dec 6, 2016 11:14 AM
Aune163rd
21
Feb 21, 2012 10:39 AM
