Solid motor mounts
Old Jun 29, 2019 | 06:52 PM
Blown 331's Avatar
Blown 331
Solid motor mounts
Anyone know where I can find solid motor mounts for an 87 F250 with factory 460? All I can find is sold mounts for swapping from a 302 or 351 to a 460. I need mounts with 2 studs on each side. All the swap mounts have one stud on each side and they don't line up. Thanks.
Old Jun 29, 2019 | 10:08 PM
Briansshop's Avatar
Briansshop
https://autofab.com/i-9621951-80-96-...on-mounts.html
Old Jun 30, 2019 | 08:03 AM
RenoHuskerDu's Avatar
RenoHuskerDu
Wouldn't you have problems with stress cracking on the mounts or the frame?
Old Jun 30, 2019 | 09:26 AM
Blown 331's Avatar
Blown 331
Says they fit Bronco so swap mounts again. It looks like they would work because they replace the perches bolted to the frame. But at that point I might as well grab 302 / 351 perches to bolt on my truck and use much cheaper conversion mounts like trans dapt. I'm looking for direct bolt in solid mounts for a truck with a factory 460. It appears they do not exist which seems a odd to me.
Old Jun 30, 2019 | 09:27 AM
Blown 331's Avatar
Blown 331
I've never heard of this being an issue. It could always be repaired.
Old Jun 30, 2019 | 09:44 AM
speedfreak78's Avatar
speedfreak78
Some steel plate, some bolts and a drill and make your own that mimic the stock ones. They don't look all that complicated.
Old Jun 30, 2019 | 09:47 AM
Mudsport96's Avatar
Mudsport96
Just add some steel to the factory ones to make them solid. Done it before, works fine.
As long as you can weld
Old Jun 30, 2019 | 09:57 AM
Blown 331's Avatar
Blown 331
Yep. Probaby going to make something or swap out the factory perches for small block perches, then run solid conversion mounts.
Old Jun 30, 2019 | 01:26 PM
Briansshop's Avatar
Briansshop
Not sure what swap mounts means. It says they work on F250/350.
Old Jun 30, 2019 | 01:34 PM
Blown 331's Avatar
Blown 331
Swap mounts meaning engine swap. They arent specifically made for replacing the stock motor mounts in a factory 460 truck. It's a whole new set up to work in any truck regardless of the original engine.
crazed87bronco
27
Apr 22, 2011 12:30 PM
oldmansimek
Dec 25, 2006 11:50 AM
Tiremine
May 15, 2006 09:13 AM
mikew460
Mar 14, 2004 11:35 AM
RichardMaerz69
Jan 18, 2004 12:58 PM
