Need some brake help
Old Jun 23, 2019 | 08:34 PM
gostephen's Avatar
gostephen
I'm have very little brake pedal, no brakes till pedal is about 90% down
I installed a new master cylinder (old one blew a seal)
New rear wheel cylinders, hardware, shoes and turned drums.
All brakes are adjusted
I bled master cylinder and all wheels
I'm stumped
75 f250 Highboy 4x4
Front and rear drum brakes
Old Jun 23, 2019 | 09:39 PM
440 sixpack's Avatar
440 sixpack
Does the pedal return to the normal height ? sometimes you have to adjust the length of the rod to fit a new MC.
If that's not it you probably still have air in the system. it can be a real SOB to get everything bled sometimes.
Old Jun 23, 2019 | 09:49 PM
gostephen's Avatar
gostephen
Yes the pedal returns to full height
I will look at the rod length
I vacuum bled it and used the pedal
Old Jun 23, 2019 | 11:26 PM
440 sixpack
Did you bench bleed the MC ? if not you're going to have to bleed it to death to pull the air through the slave cylinders
Vac with pedal is how I do it too. but more than once I've had issues.
Old Jun 24, 2019 | 07:11 AM
ranger140892's Avatar
ranger140892
Grumpy goat
If your master cylinder is bled, and everything else mentioned is right, I'd suspect the proportioning valve. Best brake modification I've done is bypass/delete the proportioning valve and installed adjustable valve on rear brake line only.
Old Jun 24, 2019 | 11:35 AM
Mark8man's Avatar
Mark8man
Most likely one of 3 things.
Master cylinder not bench bled
Improperly adjusted or assembled shoes resulting in too much travel before contact with drum. (Try pinching the rear brake hose off with vise grips. Not so tight to damage hose, just enough to block fluid. If you get better pedal problem is with rear brakes)
Master cylinder is defective and fluid is passing by the piston seals
Old Jun 25, 2019 | 02:24 PM
wdfp's Avatar
wdfp
The last thing mentioned above is becoming quite common anymore, new in no way guarantees a good product at all..
Old Jun 25, 2019 | 03:12 PM
caravaggio2000's Avatar
caravaggio2000
I swore there was something wrong with my new master cylinder or my install until I went through and bled everything a second time. That's the easiest place to start and might solve your problem.
Old Jun 25, 2019 | 10:56 PM
gostephen's Avatar
gostephen
I'm going to try bleeding it again
Double check the shoe adjustment
Check the pushed length I used the one in the truck not the one that came with new master cylinder
granny_rocket
Sep 28, 2012 07:34 AM
lorolr
13
Feb 14, 2012 09:54 AM
jenkinsj
Jun 20, 2008 08:08 AM
dickboyd69
Jul 3, 2003 03:14 PM
dickboyd69
Jun 13, 2003 01:36 PM
