Stock Stereo?
Old Jun 23, 2019 | 05:50 PM
jeremywatco's Avatar
jeremywatco
Stock Stereo?
Putting in a centech harness and while I'm at it want to replace the junk Kenwood that the PO put in.
First question, did I have a stock Stereo? The hole appears to not be cut. See picture.
Second, where did the stock speakers go? See other pics. It appears speaker holes were cut. Is this where the stock ones went? Will they fit in these cutouts?
Lastly, if I did have a stereo stock I'd like to get one of those retro ones with modern features. One catch, they need the stock radio bezel. Where would I get one?
Old Jun 23, 2019 | 06:10 PM
josht's Avatar
josht
Your cab is a 67 model, which makes parts of it unique. Radio components being one of those parts. The radio bezel and radio were 67 model year components only, 68-72 components are not a direct fit.
First question, impossible to say. It has the hole in the dash for a factory radio, but they also had a radio delete plate that would have been installed without the radio. As I understand it your dash had been "cut" to clear an aftermarket radio install. Fortunately it wasn't cut much, there would normally be two brackets in the radio hole that the shafts on the stock radio would go through for mounting the radio to the dash, then the bezel would install over the radio.
Second Question, stock radio was under the center of the dash. Looking at the last picture, you see the holes in the top of the dash. The stock speaker would have been bolted in right there aimed up at the windshield and that's the only stock speaker location for a 67-69. The other cutouts you mentioned so look like they were meant for speakers, but they were not stock.
Lastly, I'm not sure of anyone makes a radio like you want for the 67, it was 1 year only and smaller than later years. Best chance to find a 67 bezel is eBay, or search the various forums and Facebook groups.
Old Jun 24, 2019 | 08:33 AM
Freightrain's Avatar
Freightrain
Agree, a '67 has a narrow radio dial set up and likely never find a bolt in, retro radio for it.
I had a '67, I cut the tabs off(for the *****) and used a DIN mount adapter. If actually worked out pretty well, the radio bezel covered it fine and looked good. I didn't have to hack the dash to make it to fit like your PO.
You are going to have to do some metal work to get anything to fit correctly and fix the mess you have.
Old Jun 24, 2019 | 01:51 PM
Jon Richard's Avatar
Jon Richard
Old Jun 24, 2019 | 03:19 PM
Freightrain
Still need to weld the dash back together. Might look at getting whole new dash panel?
Old Jun 24, 2019 | 03:26 PM
jeremywatco
It fits a DIN stereo perfect. Maybe I'll just throw a retro DON stereo in
Old Jun 25, 2019 | 01:05 PM
Lrrr-RulerOfOmicronP's Avatar
My dash still has the brackets for the original radio but had the tabs that the face panel screws to cut out. I planned on bonding some sheetmetal tabs in so I didn't burn all paint off the dash welding.
Something like this should work Something like this should work
Would just require making the brackets, clean the metal and bond them in.
oldbleu
Jun 15, 2024 01:14 PM
Cobwebman
23
Jun 28, 2016 07:34 AM
1948 F1dude
Apr 29, 2014 07:36 PM
664x4drvr
Aug 11, 2010 04:50 PM
unforsakenn
Apr 27, 2009 10:43 AM
