300 Flywheel Replacement Question
Old Jun 24, 2019 | 06:25 PM
Boostingaz's Avatar
Boostingaz
I removed a C5AE-6380H and purchased a part number EOTZ-6375A as that is all I could find. Number of teeth etc made it seem like it would fit, however the bolt pattern for the pressure plate is off. The pressure plate fits over one bolt hole but on the flywheel but there is no second pressure plate hole that lines up. Only 3 of the 6 holes match up. Anyone know what the correct flywheel part number is for a 300 with an 11".
Old Jun 24, 2019 | 07:44 PM
john jamieson's Avatar
john jamieson
If ND doesn't answer, Try asking on the Inline 6 engine forum further down
Old Jun 25, 2019 | 04:06 AM
GaryKip's Avatar
GaryKip
"Boostingaz" I sent you an email.
Old Jun 25, 2019 | 09:22 AM
Boostingaz's Avatar
Boostingaz
I didn't receive anything?
Old Jun 25, 2019 | 10:15 PM
1browski's Avatar
1browski
What is wrong with the flywheel? If its only the ring gear just replace that and keep the flywheel. I dont have a 300 but I just put on new ring gear for a 360fe.
Old Jun 26, 2019 | 04:56 AM
GaryKip's Avatar
GaryKip
Ok since that didn't work, I sent you a PM (Private Message).
Boostingaz
Jun 26, 2019 07:23 PM
OBS Mule
Mar 5, 2017 09:42 AM
bullnose1985
May 22, 2016 09:42 AM
dogmantra
Aug 15, 2010 04:29 PM
Reptar360
Sep 27, 2007 06:26 PM
