Speed Sensor
Old Oct 5, 2003 | 12:16 AM
HaroldCallahan's Avatar
HaroldCallahan
Speed Sensor
I need to know how to get the connector off of the rear speed sensor on the top of the differential.
Then once I get the connector off, how to check the sensor.
Old Oct 5, 2003 | 08:35 AM
jamesbell's Avatar
jamesbell
If your having problem like ABS light, erratic speedometer reading below 30 mph, adn possibly hard shifts if its automatic just go to the dealer and replace it for less than $20.
Old Nov 14, 2005 | 04:26 PM
mburec's Avatar
mburec
Smile Perfect
jamesbell,
i am having the EXACT problem that you described, speedo works erratically < 30 mph, shifts(auto) HARD(THUNK) from 1st to 2nd, and ABS always on.
Rear speed Sensor on the differential?
thanks for the help
Michael
Old Nov 14, 2005 | 07:12 PM
RangerPilot's Avatar
RangerPilot
Yep it's on top. I think there's a 5/16 bolt holding it on, but dun quote me on that.
Pop the old one out, pop the new one in.
I think it's normal for it to bounce a bit, mine does it 'til about 20-25 mph, I think it's just an old school gearing sensor like mine is. No hard shifts for me though (manual is the only way to go baby).
Old Nov 14, 2005 | 07:45 PM
mburec's Avatar
mburec
hehe yea, i went under the truck and looked at where it is tonight. I wanted a manual but couldn't pass up the deal i got on this one when i lived in irving texas
thanks for the help
Old Nov 14, 2005 | 09:00 PM
juggshunter's Avatar
juggshunter
Harold I just had mine out over the weekend on a 1996....good idea to blow of the area around it real well as it is a dirt trap in that area...the release clip for the connector was easily found by looking up on top. On my ranger the bolt was metric 12 or 13 mm I think. I had to replace the o ring on mine after getting it out because of the remaing grit and twisting it back and forth to get it to come free...the retaining clip was attached to the sensor and came off with it. I cleaned mine with contact cleaner oiled the o ring with engine oil and reinstalled...didnt correct my ABS LIGHT but hopefully it will repair your problem. If you have a digital ohm meter you can check the sensor prior to removal...I can look that info up for you if you need it...good luck
Old Nov 14, 2005 | 10:01 PM
RangerPilot
You might need to reset the system jugg, unplug your battery for 20 mins then drive around and see if the ABS stays off.
Old Nov 15, 2005 | 08:47 AM
mburec's Avatar
mburec
Smile
Thanks guys for the help
vronp
Jan 19, 2014 11:29 AM
slider6075
Oct 23, 2012 09:27 PM
grosseile88
Sep 10, 2011 10:37 AM
TexasGuy001
Nov 4, 2010 04:59 AM
