6.0 upgrade
i have been reading your posts and solutions for sometime and find your insights very helpfull. My 2006 6.0 has about 25k on the clock. The following simple upgrades are Elc coolant at 10k, coolant filter at that time, oil changes at 2.5k with synthetic. Stc tuner to effeciency tune. Scan gauge 2, fuel filters at 2k, revx every other oil change. North Star pure lead batteries (ficm protection). Turbo center changed under warranty for sticking vanes at 15k. ( low use )
Having said that I know I need to open the truck to change the stc filling, dummy plugs and add tube style egg cooler.
my question is while I’m in there what else would be a worthwhile investment?
thanks
mike
I’m glad to learn from everyone else’s experience with these motors before I have to spend big money on it.
thanks
mike
Injector Cup Nipple Master Kit
Frankly I'd suggest to the OP to change the oil filters every other oil change (5K) and Fuel filters are way over kill at that miles, but do them that often too - makes the schedule easy...
Do you monitor temps etc. with your SCT? (excuse my ignorance, but I don't know what they can do). If you can you can get an idea of your oil cooler's health by getting it good and warmed up and as steady state as you can drive it, see where oil versus coolant is. It isn't relevant if the coolant isn't in the 190 range, but if you get it there, how much higher is your oil temp? Over 10 degrees and I'd go ahead and put in the updated OEM oil cooler with the updated SS pick up screen. Since the turbo will be off, have it bench cleaned/inspected - the unison ring can rust and freeze up with low use.
You should also consider some things that aren't on a "what else while I'm in there" list: put the updated blue spring into your Fuel Pressure Regulator; swap out your trans pan and internal filter to the '08 + pan/filter (filters 100% of the time). Make sure your charging system is good (minimum 140A alt.) and batteries are strong and kept charged - check that your ground connections are clean and tight and consider adding some extra ones as well as hotside cables (in Tech Section).
You can read what I did in my sig line, most of it was because I was going in after a suspected going south oil cooler...
Scott
The ScanGauge monitors eot and ect, right now within 6 or 8 degrees Was there an improvement made with the oem cooler after 2006?. I was thinking the bulletproof external cooler would be the way to go, a bit pricey though. What’s the deal with the 2008 transmission pan any literature about it?
mike
mike
On the '08+ trans pan and filter: They went to a different (and better I think) way of handling the trans fluid filtering. Your trans has to get up into the 160+ range before it sends more than a slip-stream of fluid to the front coolers. When that happens there is a bypass filter up there that will capture about 10% of the stream to the coolers. Yes, 90% goes by the fine filter... In your trans pan you have a fine mesh filter, as delivered - the '08 pan and filter will filter 100% of the trans oil whenever the engine is running, and the filter is finer filtering than even the up front one on our trucks... So it is a head-slap: why not! question for all of a hundred bucks or so (to switch to the '08+) and get full filtering all the time...
BUT, keep a filter up front - from all I have gathered, a fully clogged filter up there is better than an empty canister as it will sent the fluid to the coolers, without the filter the trans fluid runs hotter, go figure...
Scott
I fully concur that that changing fuel filters every 5k is way overkill, but I suppose it matters if he is running a fungicide to prevent algae buildup. It would likely be less expensive to run that in lieu of changing filters that often.
As far as the 08 pan and filter, I am a huge fan. While he is in there, he can also replace the singular pressure switch (that isn't used anyway) with a billet plug and change over to the different EPC and Direct solenoids to increase the fluid flow to better protect the trans in it's native shifting from 3rd to 5th gear.
Yes, all of the things that we are talking about in this thread are available on my site (alternator options included), but they are just good maintenance.
We're all in this together. Anything that we can do to have our beasts last longer are just a win.
Both valuable opinions that I will consider. The trans never seemed to get hot even pulling the 14k boat up grades but seems to be a simple upgrade and it’s about time for a trans fluid replacement anyway.
mike
You should still do it.
https://youtu.be/Ha8xa7kRcvg
