Bending AC Lines
Old Jun 21, 2019 | 09:44 PM
EXSwap's Avatar
EXSwap
Bending AC Lines
I need to reroute or bend my main AC lines that come off of the compressor to get around the lower radiator hose outlet on the 12V. Anyone have experience bending the large AL lines? Any tips or tricks? Really just need to push them back so they clear and don’t need to go far. I’d be straightening them actually, as they are basically at a 90 coming out of the pump. Thanks in advance!
Old Jun 22, 2019 | 07:29 PM
Excurvelle's Avatar
Excurvelle
Pipes do not like to bend, they develop kinks and A/C lines carry pressure. You may be able to get a little bend out of them but be careful.
Old Jun 23, 2019 | 06:37 AM
EXSwap's Avatar
EXSwap
That’s what I was thinking. Thought about heating them a bit, but to your point, I don’t need a pressure line rupturing. I’ll have to mock it up a bit further and see where it’s at and go from there. May be able to cut them and then adapt from there. Thanks!
Old Jun 23, 2019 | 09:55 AM
alloro's Avatar
alloro
No, no, no, no, no...the only proper way to bend the tube and avoid damaging it is with the correct size bender.
Old Jun 23, 2019 | 08:05 PM
EXSwap's Avatar
EXSwap
I may look at getting a quality tubing bender to see if it’ll work. This part works with the dodge compressor and then the lines get crimped on.
https://www.dieselconversion.com/a-c-manifold.html
Crazy idea I just had was maybe I’ll rotate the compressor 90 degrees and see if I can get it to clear. It’s so dang close I have to scrap the compressor and go with a new dodge version and then buy the conversion lines.
Old Jun 24, 2019 | 12:08 PM
01__Excursion's Avatar
01__Excursion
Not recommended to rotate the compressor due to the oil sump. Would be equivalent to rotating the motor 90.
Old Jun 24, 2019 | 09:18 PM
Restlesswildman's Avatar
Restlesswildman
If you have any friends that can tig weld, you could always cut the tube and manipulate how you need it. Then weld it back together....
Old Jun 25, 2019 | 07:59 AM
EXSwap's Avatar
EXSwap
I actually have a friend that can weld it and discussed it with him last night. Now to get a final mockup and see exactly what I need to do. I'm hoping I can cut the lines at the block that bolts to the compressor and shorten them and make it work. If not, I'll have to find some tubing.
Thanks for the responses all!
ske
1997 - 2003 F150
Jun 29, 2016 09:51 PM
Hotel
Sep 8, 2014 08:12 AM
xltblt
Mar 8, 2012 04:57 PM
thordehr
May 25, 2010 10:34 PM
