Replacing full size starter with headers installed?
Old Jun 21, 2019 | 08:33 PM
daveinva's Avatar
daveinva
So, I'm going to go ahead and replace my starter on my 360FE with headers installed. The current starter is a full sized starter and it sits in there fine for clearance with the headers. But, it doesn't look like I can get it out without unbolting the passenger side header.
Is that a pretty standard way to replace the starter when headers are installed? If I unbolt the header will I need a new exhaust gasket or can I pretty much reuse the current one if it's intact? Does anyone know the torque specs on the header bolts?
Also, does anyone have a good recommendation for a heat shield blanket?
Dave
Old Jun 21, 2019 | 09:56 PM
mark-guiver's Avatar
mark-guiver
Yes you probably are going to have to remove the header to get the starter out. On my truck I used SCE # 4134 copper gaskets about 17 years ago and they have worked great for me. I've had to remove them a couple of times over the years and have reused the same gaskets with no leaks. Torque spec. is around 35 LB. FT., but I just tighten them up good by hand , check tightness after 100 miles or so and forget about them. Have never had one come loose doing it like that, beside the fact that you cant get a torque wrench on about 1/2 of the bolts. Summit, JEGS, and some of the better parts stores sell the starter heat shields. I've used the DEI shield and have no issues with the functionality.
Mark.
Encho
1978 - 1996 Big Bronco
17
Sep 9, 2013 01:04 PM
camperspecial65
Nov 24, 2008 10:12 PM
stargazer
Dec 26, 2003 10:28 AM
cowgirl_truckin
Mar 21, 2003 06:52 PM
jspegg
Apr 18, 2001 03:37 AM
