Anyone care to share what screen setup you run in torque pro? Also, are you able to monitor your trans temps on yours? I got the MX+ but it always reads 212F for mine even at cold start.
I use the Ford OEM-inspired theme and PIDs @Tugly created and shared with us a little way back when. Trans temp reads fine on one of the options. I don't remember which one it is ATM. Try a different one.
Theme is one thing but all I did was to load some Ford PIDs. Is that what you are talking about?
The ZF6 will not see transmission temp, but it will see engine coolant temp. Many of the PIDs have similar names, some are duds. You might need to find a different one similarly named, but no promises it will work correctly without tweaking the formula.
