Trying to find specs on these tires... procomp website offers none. I want to go either a 285/75/16, 295, or a 305/70/16 but dont know if they will fit without a lift (03 f250 crew 4x4 v10)
I found 305/70/16's to be the same as a 33/12.5/16 and spec out to 32.6 dia. 12.6 total width 10.1 tread width and able to fit an 8-10" wheel. Is this correct?
anyone know if these will be ok on stock wheels?
also curious if anyone can tell me what the 285/75/16, and 295's are equal to and what the specs are?
procomp dosnt even list a 295 let alone specs...
im confused
stock rims are 7", some places dont want to mount 295s on 7" rims and definately not on 305s. Some places will though and there are people running them on stock rims so it depends on where you go. With the stock backspacing more than likely 305s will rub and 295s might depends on the tire, ive heard somewhere about people running 305s and no rub and some say 295s rubs on other tires *shrug* I probably havent helped any, I havent seen the procomps in use myself so I cant say for sure about them
according to straight up math conversions 285/75/16 should be 32.8x11.2 but the 7" rim and sidewall flex, etc will probably skew those numbers. 295s are 11.6" theoretically, 295/70R16 would be 32.2x11.6
