Sponsored by: Real Truck
Steering Gear Question
Old Jun 21, 2019 | 04:06 PM
mcewan79's Avatar
mcewan79
apparently Lares does. i have no idea if junk or not, but some searching online found a couple positive reviews. fingers crossed.
Old Jun 21, 2019 | 05:00 PM
brian42's Avatar
brian42
Veteran: Navy
Good luck!
Definitely post your results as I don't remember the last time there was a review of a new steering gear.
Old Jun 22, 2019 | 10:18 AM
Brian Hanks's Avatar
Brian Hanks
Yeah hate to break it to you but Rockauto Motorcraft is the one I put in. It’s a reman..
I just found one other issue with my truck last night when we were replacing brakes and rotors. I found one of my tires was wearing badly and part of the steering issue compounding everything was the fact that one of my auto lockers was still locked. UGH. When Locked it makes a really funky noise so either the auto hub is shot or I’ve got bigger problems now... I am getting rid of the auto lockers now and just ordered some manuals.
I will say I just put on some power stop Z 36 extreme duty brakes and rotors and man I think My passenger had to put his hand on the dash the first time I did the aggressive braking portion of the brake and rotor seating process.
Old Jul 7, 2019 | 12:28 PM
mcewan79's Avatar
mcewan79
So, new box is in. Issue persists. It does seem to drive better, some improvement, but its still loose. Video of new box, you can see the issue looks the same as the first video i posted. I think its a little stiffer than the first box (after I tightened the first as well). I'll send a message to Lares, see what they say. The movement in the video is only at the box, no movement at all on pitman arm side. Rag joint seems fine. Not sure why the box isn't tighter thus making the steering wheel tighter. Hmmmm.
Old Jul 7, 2019 | 02:07 PM
wiredgeorge's Avatar
wiredgeorge
I went through this ordeal. Replaced front end stuff (ball joints, tie rods, etc). Steering was still sloppy. Replaced the steering damper. Helped but still sloppy. Noticed my cab to frame bumper cushions were shot and replaced those and the steering is now fine. Guess it wasn't all steering but the cab flopping around. Truck rides much better. Did not buy OEM as only two are rubbery type material and the others are angel good cake or something; bought poly kit off Amazon. The OEM stuff is pretty much trash.
Old Jul 7, 2019 | 09:01 PM
Mickey Bitsko's Avatar
Mickey Bitsko
How did you discover your front cab to frame mounts were bad?
Old Jul 8, 2019 | 12:43 PM
wiredgeorge
Crawl under. Four of the bumper things are yellowish in color and they were basically trash; just parts of them in place. Ther ones in the center of the cab are black and a rubber type materials and the ones at the rear were torn visibly and the ones up from under the hood were actually in decent shape. You can see these by turning your steering wheel and looking behind a wheel. The ones under the cab are sandwiched between frame and cab. Easy to see. There are bumpers in back where the springs can contact the frame and these are also made out of the yellowish stuff and mine were almost totally gone. These take just a few minutes to change but I doubt affect ride any but are there to prevent the springs from klunking on the frame.
Old Jul 26, 2019 | 09:15 AM
mcewan79's Avatar
mcewan79
I showed this video to Lares, they say the new box is defective and I should replace it. As such, hopefully third time is the charm here. Uhg.
Old Jul 29, 2019 | 09:10 AM
Mickey Bitsko
I have posted on this thread before about what I think is my steering box, but now I'm questioning my shocks and air bags and maybe my tires.
I carry a 1800 lb slide in camper, driving on the freeway in hot NM yesterday any variation in road surface caused the truck "wallow" for a second and cause an easily over correction thought I was going roll, scared the hell out of me. PO installed new Monroe something or other shocks front and rear, might have 7k on them. Falken lr E @ 70 lbs air bags@ 12 lbs.
Not sure if this is where to post, any suggestions?
On a previous post, all front steering components are new accept steering box.
00' 250 sd
Old Jul 29, 2019 | 02:02 PM
Dan V's Avatar
Dan V
00' 250 sd
Plumb your air bags independent of each other.
Old Jul 29, 2019 | 02:26 PM
Mickey Bitsko
They're plumbed separate.
Old Jul 29, 2019 | 07:01 PM
Magoo22's Avatar
Magoo22
I had a similar deal with my 2007 and finally bit the bullet and bought a Red Head Extreme duty steering gear. Pricy for sure but it is essentially a F550 steering gear and my truck now feels like it is on rails.
And don't forget about increasing castor. 4.5 deg. was my lucky number...
Old Jul 30, 2019 | 11:59 AM
  #28
AACoPD05's Avatar
AACoPD05
Same boat here, but on my '01 with 271k on it. Same amount of play. Was thinking about doing the Red Head steering box but have heard some complaints, so I will probably do an OEM reman. Keep us posted.
Old Jul 30, 2019 | 03:35 PM
  #29
brian42's Avatar
brian42
Veteran: Navy
I also went a more budget-conscious route than a Red Head and got a Blue-Top. I was very happy with it.
Bowie
Jun 10, 2017 07:00 PM
titanminator
Nov 19, 2010 03:47 AM
climbon
Aug 4, 2007 08:53 PM
bigorangenation
Jul 16, 2004 01:21 PM
seymour
Jul 3, 2002 03:56 PM
