Rear spring install help
Old Jun 18, 2019 | 08:20 PM
Macmathews's Avatar
Macmathews
installing new rear springs from ATS and need some advice on how to proceed..
Removed drivers side stock spring and replaced with new spring (the passenger side stock spring is still connected.
The bolt holding the spring pack is not lining up with the required hole in the bump stop tang..
The bolts on the ends of the springs are just finger tight so far.
I am sure this is somehow related to the fact that these springs have alot more shape than the worn out stock springs.
I'm just not sure on how to proceed.
FYI - Springs may look thin because I have removed the overload on the bottrom.
Left of image is towards front of truck
See images
Old Jun 18, 2019 | 08:48 PM
Dan V's Avatar
Dan V
You're just going to have to wrestle the pin in to the hole.
Old Jun 18, 2019 | 08:58 PM
thor363's Avatar
thor363
I used a ratchet strap to put mine back together (actually a couple of them). Made it much easier than trying to fight that steel. Oh yeah,, and if the opposite side spring is already tightened down it'll be even harder.
Don't torque anything to final spec until the truck has been set down and moved a bit to settle it. This is noted in other similar threads. Good luck.
Old Jun 18, 2019 | 09:02 PM
bluovl's Avatar
bluovl
Make it easy on yourself and disconnect the drive shaft. That way you'll be able to move the rear end back and forth.. Your slip joint may need some lube.
Old Jun 18, 2019 | 09:17 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Loosen opposite side ubolts, ratchet strap axle into place, install ubolts loose but tight enough to hold everything in place, do the other side.
Old Jun 18, 2019 | 09:22 PM
pirate4x4_camo
what ride height are you hoping that turns out ?
with that setup I foresee it being lower then stock 24” hub to fender.
Old Jun 18, 2019 | 09:23 PM
bluovl's Avatar
bluovl
HMM?
Old Jun 18, 2019 | 09:28 PM
Macmathews's Avatar
Macmathews
Thank- you
Thanks for the tips guys..
I'll give it a whirl tomorrow
Kyle
Old Jun 18, 2019 | 09:30 PM
Macmathews's Avatar
Macmathews
These new springs measure about 2" higher than what I removed, on the floor , loaded will be different . I plan on adding airbags
I am more concerned about axle wrap towing, before I get the funds for some kind of traction bar setup
Thoughts ?
Kyle
Old Jun 18, 2019 | 09:47 PM
pirate4x4_camo
Thoughts ?
Kyle
Use the stock Excursion traction bar, it works well. Or just don’t accelerate from a stop at full throttle.
Old Jun 18, 2019 | 10:43 PM
wpnaes's Avatar
wpnaes
I used the front bumper winch to pull the rear axle forward a 1/2 inch to align that bolt and hole. That was without loosening the opposite side. Ratchet strap or come-along should work too.
post #3. https://www.ford-trucks.com/forums/1...c-springs.html
Old Jun 19, 2019 | 10:56 AM
Macmathews's Avatar
Macmathews
Ok guys UPDATE..
I just did a measure of axle to axle on both sides and there is a 1.25" difference between sides..
Thankfully in the favor that I need 5/8" seems about what I need..
I'll post up pics when I decide on what version of springs to install - Thats another story / thread
Kyte
Old Jun 20, 2019 | 07:48 PM
Macmathews's Avatar
Macmathews
All bolted up..
Ended up being a breeze with the other passenger size spring removed..
slid around on the floor jack into place like nothing..
See image, U bolts are a little long
Kyle
Old Jun 20, 2019 | 08:02 PM
pirate4x4_camo
I would be curious what your ride height is with that setup.
measure from the center of the hub straight up to the bottom of the fender arch.
thank you
Old Jun 24, 2019 | 05:44 AM
Macmathews's Avatar
Macmathews
thank you
26 1/2"
I measured before and after and with 5 gallons of fuel the additional lift is 2 - 2 1/2"
I havent driven it yet
Kyle
