DPF Replacement
Old Jun 18, 2019 | 07:27 PM
slowfarmer's Avatar
slowfarmer
DPF Replacement
Has anyone done this yet? I have read average lifespan on these is 100-125k (correct me if Im wrong) Im at 132k so beginning to think about it. I would delete but I live in Mass where they do test for readiness at annual inspection. Seems like a relatively straight forward job. One question - the factory service manual says after replacing to do a DPF system parameter reset, SCR parameter reset and clear continuous PCM DTCs/reset emissions monitors information in the PCM. Can these three functions be done through forscan?
Also are there any good sources for a new DPF? Thank you
Old Jun 18, 2019 | 07:31 PM
UGA33's Avatar
UGA33
I’ve seen them go much farther than that on average. Not sure on all the resets. Replacing the DPF would be pretty easy and cheap. Find a guy in a neighboring state that would sell you theirs when the time comes. For instance, mine was removed at 800 miles after deleting. They usually sell for $4-600 bucks used versus $2,500+ new from Ford.
Old Jun 18, 2019 | 08:01 PM
white_dc's Avatar
white_dc
Pretty sure if you ask in the forums or FB groups you will easily be able to find someone that will sell you their low mileage DPF. Plenty of guys are wanting to delete, and i'm sure they would love to offset the costs.
Old Jun 20, 2019 | 05:49 AM
slowfarmer's Avatar
slowfarmer
Good idea I will do that
Old Jun 20, 2019 | 09:25 AM
Sport45's Avatar
Sport45
I believe the design life is in the 250,000 mile range. You should have a good bit of time to research a replacement.
Old Jun 20, 2019 | 04:55 PM
TeddyD's Avatar
TeddyD
If you want your filter to last, clean it. There are cleaning solutions that you spray into your DPF system through an access hole. Most of the solutions require you to do a regen after the cleaning process
Old Jun 20, 2019 | 05:55 PM
RONMCHUGH's Avatar
RONMCHUGH
Romcjr
I have no info on this , can you elaborate ? Thanks
Old Jun 20, 2019 | 06:45 PM
TeddyD's Avatar
TeddyD
something like this. I was at the dealership the other day and saw they had a few bottles of the motorcraft DPF cleaner.
Old Jun 20, 2019 | 10:55 PM
Jefff H's Avatar
Jefff H
Mine went 230K before I got rid of it. It's probably still going fine.
Old Jun 21, 2019 | 05:33 AM
slowfarmer's Avatar
slowfarmer
Interesting and good to know they should last closer to 250k. I will look into cleaning as well - didnt know that was an option. None of my trucks have ever had the def and dpf system so this is all new to me.
Old Jun 21, 2019 | 04:00 PM
RONMCHUGH's Avatar
RONMCHUGH
Romcjr
https://youtu.be/020MdntTw34
Interesting video …. , I didn't know that was possible .
Old Jun 21, 2019 | 05:01 PM
2009kr's Avatar
2009kr
That was interesting. I wonder if there a Ford-approved process like that that the dealer will do.
Old Jun 21, 2019 | 05:08 PM
RONMCHUGH's Avatar
RONMCHUGH
Romcjr
Just saw this . https://www.ebay.com/itm/Valvoline-D...53.m1438.l2649 Has anyone used this or a similar product ?
Old Jun 21, 2019 | 06:29 PM
TeddyD's Avatar
TeddyD
I don’t know what Ford charges for this DPF cleaning service but a few years ago, dodge was charging $1000CAD for a “DPF Service and Cleaning”
Ford dealers sell their version of the spray. This is something that I don’t think you would want to do numerous times. I’d say clean it at 80,000 mile intervals would be a good guess. Over cleaning will result in excess and unnecessary wear.
Old Jun 21, 2019 | 06:32 PM
TeddyD's Avatar
TeddyD
It’s amazing what happens when you can’t sleep so you start watching YouTube videos and get stuck in that YouTube vortex. Lol At least this time, I didn’t end up on a video of how to steal from Walmart. 😂
