Transmission Gaskets
I need part numbers for this transmission for gaskets. The pan has 13 bolts. Transmission is hooked up to a 292 y-block.
At least two areas on this transmission leak a little, where gaskets are. Here are a couple of pictures of transmission. Is there a gasket kit for this?
The pan - could it be 14 bolts? As I look at it I can't see them all but if I fill in the blanks I think I can account for 14 - and it looks like an MX Cruise-O-Matic from some of the other outward appearances.
On the drivers side of the transmission might be a tag with the numbers. That can help identify which COM it is, assuming that's what it is.
They do make gasket and oil seal kits. This kit is, I believe, correct for a few models including the PDB-D that I have. Depending on which year and model of COM they have different kits and individual parts.
C1AZ-7153-F - GASKET and OIL SEAL KIT
You can also get just the individual gaskets and seals in the kit so if you just need some of them they are available, too, for the most part.
http://www.charlietranny.com/Fordoma...des_Page_4.jpg
It might be 14 bolts (ran out of fingers at ten, was wearing shoes, so I had to guess after that
Original trans for the 1964 292 y-block.I looked for a tag while it was up on the rack couldn't find one so I came here knowing there are people here such as yourself with this knowledge.
Thank you again.
Fordomatic transmission
Ooops, same link as post 3.
B8AZ-7153-G .. FX Gasket & Seal Kit / Obsolete
CARPENTER NOS OBSOLETE PARTS in Concord NC has 2 = 800-476-9653.
NOS PARTS LTD in Waxahachie TX has 3 = 972-937-2201.
GREEN SALES CO. in Cincinnati OH has 5 = 800-543-4959.
OBSOLETE RELIABLE PARTS in Nashville GA has 5 = 229-686-5101.
Note: The gasket/seal kit that Chad listed (C1AZ-7153-F) is in-correct, it's for MX Cruise-O-Matic (aka BIG Cruise-O): 1965/67 F100/350 352, 1965/72 F350 300 I-6 // Misc 1958/67 Ford/Merc Passenger Cars.
The MX uses...besides other things, a different pan gasket and filter than the FX
Both the FX & MX have 14 trans pan bolt holes.
