extended warrenty
I'm only thinking of it because of all of the electronic stuff on it, 20K on the truck now so only 16k left on that warranty, the motor and drive train already have 100k warranty on them so I would be basically paying 3K for an additional 64k warranty on the rest of the parts
what are your opinions??
My 15 currently has only had about $300 in rental coverage (repairs under powertrain warranty) right now but it's going in tomorrow for a few minor issues but will rack up another $300+ in rental coverage and this will be the first repair under the ESP. I believe my APIM has to be replaced ($600), trailer 7pin replaced, possible vacuum leak on 4x4 hubs and a sensor issue for the trans temp causing hill decent and traction control faults.
So for many, they may not work out but these are prime examples of people who do make out. Frankly I would never buy a brand new vehicle this day and age without an ESP if I plan on keeping them. Now that they offer 8year and 150,000 mile coverage.. chances are I will be able to come close to breaking even at the very least.
So although you may have lucked out and others as well, these things are too damn expensive now not to have one. YMMV.
Steering Brakes Suspension
Electrical Air Conditioning & Heating High-Tech
Emissions Audio Safety
Engine Transmission Rear/Front-Wheel-Drive Axle
• Column Lock
(Tilt Wheel)
• Control Valve
• Cooler and Metal Lines
• Electronic Power-Assisted
Steering
• Idler Arm
• Power Steering Pump/
Electric Power Steering
Actuator
• Pulley Assembly
• Seals and Gaskets
• Steering Column
• Steering Gear Housing,
Manual and Power
(Including All
Internal Parts)
• Steering Shaft
• Underbody Linkages and
Couplings
• Anti-Lock Brake
Module and Sensor
• Backing Plates
• Brake Booster (Power)
• Calipers
• Combination Valve
• ETA Pump Hose Assembly
• Metal Lines and Fittings
• Master Cylinder
• Parking Brake
Linkage and Cables
• Retainers and Clips
• Self-Adjusters
• Shaft (Brake Pedal)
• Springs
• Wheel Cylinders
• Ball Joints
(Upper and Lower)
• Control Arms
(Upper and Lower)
• Control Arm Shafts
and Bushings
• Kingpins and Bushings
• Linkage and Bushings
• Load Leveler Suspension
System
• MacPherson Struts
• Roll Stability Control
• Spindle and Spindle
Support Springs
• Stabilizer Bar
• Tie Rods
• A/C Accumulator
• A/C Clutch
• A/C Clutch Bearings
• A/C Compressor
• A/C Compressor
Clutch Switch
• A/C Compressor Head
• A/C Compressor Seals
• A/C Condenser
• Auto Temp Control
• Evaporator
• Field Coil
• Heater Blower Motor
• Heater Control Assembly
• Heater Core Assembly
• Instrument Panel
Registers and Air Ducts
• Pulley
HIGH-TECH
• Adaptive Cruise Control
• Adaptive Headlamp System
(Excluding Lamp Housing,
Bulbs)
• Air Suspension
(Selected Electronic
Components)
• Anti-Theft Alarm
(Factory-Installed)
• Auto Lock and Auto Unlock
System
• Automatic Park Assistant
• Blind Spot Info Sys
(Electrical Only – Not Mirror
or Glass Damage or Bulbs)
• Cross-Traffic System
• Enhanced Active Park
Assist Sys
• FordLink™ System
• Ford Work Solutions Asset
Security (if equipped)
• Forward Sensing Sys
• Fuel Mixer (Alternative)
• In-Dash Garmin®
Voice-Activated Navigation
System (Factory-Installed
and Dealer)
• Instrument Cluster
(Excluding Dash Pad)
• Intelligent Oil Life Monitor®
System
• Keyless Entry System
(Excluding Door Handles)
• Lane Depart Warning
• Message Center
• Power Antenna
• Power Door Locks and
Retainer Clips
(Excludes Door Handles)
• Power Seat Motors
• Power Window Motors/
Regulators
• Rain-Sensing Wipers
• Rear Console Refrigeration
• Reverse Camera Sys
• Reverse Sensing Sys
• SecuriCode™ Keyless Entry
• SecuriLock® Passive Anti-
Theft Ignition System
• Sensor (Alcohol)
• SOS Post-Crash
Alert System
• Speed Control
• Stationary Elevated Ride
Control
• SYNC® MyFord Touch®
(Excludes Software
Upgrades)
• Trailer Brake Module
• Unique Hybrid/Electric
Vehicle Components
(Excluding High-Voltage
Battery and Cables) • Air Check Valve Assembly
• Air Control Valve
• Air Idle Vacuum Valve
• Air Supply Valve
(Hose and Tube)
• Barometric
Pressure Sensor
• DEF System
(Excludes Catalyst)
• ECC Relay Assembly
• EGR Control Valve
• EGR Pressure Sensor
• EGR Regulator Asy
• EGR Valve Adapter
• Electronic Throttle Control
• EVAP Vapor Storage Canister
• Idler Air Control Valve
• Knock Sensor
• Mass Air Flow/Intake
Air Temp Sensor
• Oxygen Sensor
• PCV Hose Assembly
• PCV Valve
• PCV Vapor Filter
• Reductant Urea System
• Temperature Sensor
(Engine Coolant)
• Vacuum Restrictor
• VAF Sensor
• Variable Camshaft
Timing (VCT) Phasers
AUDIO
• Antenna, Radio
(Base Assembly)
• Brackets
• Cables and Wiring
• Cellular Phone, Receiver,
Handset, Speaker
Assembly and Antenna
(Factory-Installed)
• Compass and Therm
Readout Displays
• Controls (Rear Seat)
• Radio (AM, AM/FM),
Speakers, Cassette Player,
Digital CD Player, Graphic
Equalizer, Premium
Sound Amplifier (Factory-
Installed)
• Rear Entertainment System
(Factory-Installed)
• Airbag Module Assembly
• Collision Avoidance Sys
• Diagnostic Module
Assembly (Airbag)
• Door Ajar Warning Switch
Assembly
• Guides, Bezels, Brackets
and Supports (Safety
Belts/Shoulder Straps)
• Head Restraint Retainers
and Sleeves (Safety Belt)
• Key, SecuriLock®
(Microchip-Encoded Key)
• Lock Cylinder (Door)
• Lock Lever Asy (Door)
• Lock Lever
Assembly (Tailgate)
• Lock Lever Retainers, Clips
and Brackets
• Module (Passive Restraint)
• Safety Belt Buckle
(Front and Rear)
• Safety Belt Motor
Drive Assembly
• Safety Belt
Restraint Carrier
• Safety Belt Retractors
• Safety Belt Track Asy
• Safety Belt Warning Chime
Assembly
• Safety Canopy
• Sensors (Airbag)
• Shoulder Strap
Track Assembly
• Wiring Asy (Airbag)
**Interior/Exterior Lighting – coverage included only if
Lighting Option is purchased.
Other Components and Repairs – Fabric, liners, fasteners,
carpets, dash pad, wiper blades, *****, trim, upholstery, physical damage or
cosmetic issues, repairs covered by manufacturer recalls, any insurance or if the
vehicle is within the time and mileage limits of any warranty, repairs caused by
improper unreasonable use, unauthorized alterations or modifications of the
vehicle, and repairs caused by lack of required or recommended maintenance.
Costs or expenses for the teardown, rental expense, inspection or diagnosis of
failures not covered by this Agreement. Refer to contract for details.
Repairs Related to Your Maintenance Requirements – Items
listed in your vehicle’s owner guide. Examples include: batteries of all types and cables,
belts, hoses, hose clamps, brakes (front hub, drums, shoes, linings, disc rotors, pads),
manual transmission clutch disc, exhaust system (includes catalytic converter), spark
plugs, squeaks, rattles, tires, wheel balancing, wheel alignment, all lamps and lights (LED
and HID lights, bulbs, sealed beam and lenses) except when purchased with New or
Incomplete PremiumCARE Interior/Exterior Lighting Option, fogging of lamp assemblies,
shock absorbers, service adjustments and cleaning, and scheduled maintenance services.
Generally Covered by Your Auto Insurance –
Examples include: fixed (non-moving) body parts, bumpers, glass, moldings,
ornamentation, paint, rust, sheet metal, structural underbody framework,
side and rearview mirrors (glass and housing), water leaks, wind noise,
weather strips, wheels, wheel studs, wheel covers, convertible top and bow.
• All Internally Lubricated
Parts
• Cylinder Block
• Cylinder Heads
• Diesel Fuel Injectors
• Diesel Injector Lines
• Diesel Injector Pump
• Diesel Lift Pump
• Engine Mounts
• Flywheel
• Flywheel Ring Gear
• Fuel Tank and Metal Lines
• Gas Fuel Injectors
• Gas Injector Lines
• Harmonic Balancer
and Bolt
• Manifold (Exhaust and
Bolts)
• Manifold (Intake and Bolts)
• Oil Pan
• Oil Pump
• PCM Module
• Radiator
• Radiator Fan
(Clutch or Motor)
• Seals and Gaskets
• Thermostat
• Thermostat Housing
• Timing Chain Cover
• Timing Chain
(Gears or Belt)
• Turbocharger/
Supercharger Unit
(Factory-Installed)
• Valve Covers
• Water Pump
ENGINE
Parts
• Release Hubs and Bearings
• Seals and Gaskets
• Torque Converter
• Transfer Case (Including All
Internal Parts)
• Transmission Case
• Transmission Linkage
• Transmission Module
(External)
• Transmission Mounts
TRANSMISSION
• LED Lighting or Lamp
Assemblies – Interior
and Exterior (Factory-
Installed)**
• Alternator
• Audiophile Sound System
• Charge and Volt Gauges
• Clock (Electric)
• Control Trac® 4WD
System
• Driver’s Seat
Position Sensor
• Dual-Zone Electronic
Auto Temp Control
• Electronic Ignition Module
• Fuel Pump
• Heated Backglass
(Electrical Only –
Not Glass Damage
or Breakage)
• High-Intensity Discharge
(HID) Headlamps Igniter/
Ballast**
• Ignition Coil and Lock
• Ignition Module (Electric)
• Ignition Switch
• Incandescent/Halogen
Bulbs – Interior and
Exterior**
• Intelligent 4WD Systems
• Power Mirrors (Electrical
Only – Not Mirror or Glass
Damage or Bulbs)
• Power Running Boards
• Radiator Fan Relay
• Rear Window
Power Sunshade
• Speedometer/Odometer
(Electrical and
Mechanical)
• Starter Motor
• Starter Motor Solenoid
• Switches (Manually
Operated Electrical)
• Temperature Gauge
• Voltage Regulator
• Wiper-Activated
Headlamps
• Wiper Motors
• Wiring Harnesses
(Excluding Spark Plug
Wires)
REAR/FRONT-WHEEL-DRIVE AXLE
• Automatic Front Locking
Hubs (Four-Wheel Drive)
• Axle Shafts
• Bearings (Front and Rear)
• Rear: Drive Axle Housing
and Front Axle Housing for
4x4 (Including All Internal
Parts)
• Front: Final Drive Housing
and Rear Axle Housing for
AWD (Including All Internal
Parts)
• Driveshaft
• Locking Rings
(Four-Wheel Drive)
• Seals and Gaskets
• Universal and Constant
Velocity Joints
24-hour Roadside Assistance
1-800-241-3673
100% Backed by Ford
Transferable
1,000+ Covered
Components
Ford-authorized
Parts
Service in the
U.S., Canada
and Mexico
Ford
Certified
Technicians
Key Services
Rental Benefits
The Ford Protect PremiumCARE extended service plan
is so comprehensive, it’s easier to refer you to what isn’t
covered – here are the highlights:
High-Tech
Components
Covered
High-Tech
Components Covered
by Ford Protect.
Insist on
Ford Protect
Covered
Components 1000+
(Partial List)
• Column Lock
(Tilt Wheel)
• Control Valve
Steering
• Idler Arm
Actuator
• Pulley Assembly
• Seals and Gaskets
• Steering Column
Manual and Power
(Including All
Internal Parts)
• Steering Shaft
Couplings
• Anti-Lock Brake
Module and Sensor
• Backing Plates
• Calipers
• Combination Valve
• Master Cylinder
• Parking Brake
Linkage and Cables
• Self-Adjusters
• Springs
• Wheel Cylinders
• Ball Joints
(Upper and Lower)
• Control Arms
(Upper and Lower)
and Bushings
System
• MacPherson Struts
Support Springs
• Stabilizer Bar
• Tie Rods
• A/C Accumulator
• A/C Clutch
• A/C Compressor
• A/C Compressor
Clutch Switch
• A/C Condenser
• Auto Temp Control
• Evaporator
• Field Coil
• Instrument Panel
• Pulley
HIGH-TECH
Bulbs)
• Air Suspension
Components)
• Anti-Theft Alarm
(Factory-Installed)
System
Assist Sys
• FordLink™ System
• In-Dash Garmin®
and Dealer)
System
• Message Center
• Power Antenna
Retainer Clips
• Power Seat Motors
Regulators
• Sensor (Alcohol)
• SOS Post-Crash
Alert System
• Speed Control
Control
(Excludes Software
Upgrades)
Vehicle Components
• Air Control Valve
• Air Supply Valve
(Hose and Tube)
• Barometric
Pressure Sensor
• DEF System
(Excludes Catalyst)
• EGR Control Valve
• EGR Regulator Asy
• EGR Valve Adapter
• Knock Sensor
Air Temp Sensor
• Oxygen Sensor
• PCV Hose Assembly
• PCV Valve
• PCV Vapor Filter
(Engine Coolant)
• Vacuum Restrictor
• VAF Sensor
• Variable Camshaft
AUDIO
• Antenna, Radio
(Base Assembly)
• Brackets
• Cables and Wiring
Handset, Speaker
(Factory-Installed)
• Compass and Therm
Readout Displays
Equalizer, Premium
Installed)
(Factory-Installed)
• Diagnostic Module
Assembly (Airbag)
Assembly
• Key, SecuriLock®
• Lock Lever
Assembly (Tailgate)
and Brackets
(Front and Rear)
• Safety Belt Motor
Drive Assembly
• Safety Belt
Restraint Carrier
Assembly
• Safety Canopy
• Sensors (Airbag)
• Shoulder Strap
Track Assembly
Parts
• Cylinder Block
• Cylinder Heads
• Diesel Lift Pump
• Engine Mounts
• Flywheel
• Harmonic Balancer
and Bolt
Bolts)
• Oil Pan
• Oil Pump
• PCM Module
• Radiator
• Radiator Fan
(Clutch or Motor)
• Seals and Gaskets
• Thermostat
• Timing Chain
(Gears or Belt)
• Turbocharger/
Supercharger Unit
(Factory-Installed)
• Valve Covers
• Water Pump
ENGINE
Parts
• Seals and Gaskets
• Torque Converter
Internal Parts)
• Transmission Case
(External)
TRANSMISSION
Installed)**
• Alternator
• Clock (Electric)
• Control Trac® 4WD
System
• Driver’s Seat
Position Sensor
Auto Temp Control
• Fuel Pump
• Heated Backglass
(Electrical Only –
Not Glass Damage
or Breakage)
Ballast**
• Ignition Switch
Exterior**
Damage or Bulbs)
• Rear Window
Power Sunshade
(Electrical and
Mechanical)
• Starter Motor
• Temperature Gauge
• Voltage Regulator
• Wiper-Activated
Headlamps
• Wiper Motors
• Wiring Harnesses
Wires)
• Axle Shafts
Parts)
Parts)
• Driveshaft
• Locking Rings
(Four-Wheel Drive)
• Seals and Gaskets
Velocity Joints
1-800-241-3673
100% Backed by Ford
Transferable
1,000+ Covered
Components
Ford-authorized
Parts
Service in the
U.S., Canada
and Mexico
Ford
Certified
Technicians
Key Services
Rental Benefits
High-Tech
Components
Covered
High-Tech
Components Covered
by Ford Protect.
Insist on
Ford Protect
Covered
Components 1000+
(Partial List)
the paper can say what ever it wants but the warranty is worthless if you cant get a service appt. warranty work pays less than non warranty work and with my 7yr/125k miles ford warranty...the minute they lookup my vin and see I have a warranty ..suddenly there are no appts out for 90 days and even if I get an appt 11 or 12 weeks out..I get a call the week of to reschedule another 90 days..until ultimately the appt is cancelled by ford. all dealerships within 100 miles of high cost areas play this game. if I have a critical warranty need I have to take my truck 3 states away turn the truck in...book a hotel..and hang out for a few days. it might have been cheaper not to get the warranty and get local out of warranty appts than to have paid for the warranty plus all this travel time gas tolls hotels etc.
I once had a bad drive shaft and rather than play this game again I just bought the shaft at 1200 bucks and changed it myself.
total waste of money on my situation.
if you buy a warranty make sure you can use it
Holy thread resurrection Batman.
