I am having a hard time finding a 100% guarantee on this, I just found someone parting out a 96 f150 and got him to agree to give me all the glass but I'm not 100% that it will fit my 96 f250 extended cab ( 2 door), I have the brown privacy glasses and cant stand it anymore and my front windshield was cracked driving the truck back when I bought it. Also would the interior panels fit an f250. Thanks!!
Glass is all the same. I have one from an F150 for a window wing and another side glass from an F250 for passenger.
Windshields are glued in, not going to remove without destroying I am pretty sure. Safelite did mine for $240ish out the door with warranty. Sign in online, use a Retailmenot rebate code, and sometimes Ebates has cash back. Then use a credit card on top of that to really get the cost down.
i might do that, I can be a cheap *** so might have to try my luck with pulling it. 75$ for an entire trucks glass isnt bad . I found a video for the removal of the back glass online
i might do that, I can be a cheap *** so might have to try my luck with pulling it. 75$ for an entire trucks glass isnt bad . I found a video for the removal of the back glass online https://www.youtube.com/watch?v=wj6KV9biUrA . Doesn't look to bad, I cant find anything for the rear half windows though anyone know how they go in/out?
-P
I would guess ext cab glass is the same...I have only had reg and crew cabs though... one way to find out...try it...
-P
If I recall correctly, the extended cab side windows are held in with nuts, daughter's 1993 truck and we did it in 2008.
You have to remove the inside plastic trim and take the nuts for the window out. I used some butyl tape on the outside, put new (used) window in and gently tightened nuts down.
