Sponsored by: Real Truck
2011 6.7 question
Old Jun 17, 2019 | 10:42 AM
Crawl101's Avatar
Crawl101
2011 6.7 question
Trying to help out a stranger that was stranded, he has a 2011 6.7 that he changed out both Fuel filters , says he did the proper cycling of the key to get the fuel back, drove it about a mile and it died and wont start back up. I had my code reader on me and he is getting P20BA and P2074. I have researched the codes but it just seems strange that this happened right after changing the filters, any help or advise would be greatly appreciated.
Thanks
Chad
Old Jun 17, 2019 | 09:17 PM
dirthawg's Avatar
dirthawg
Those codes don't have anything to do with the fuel issue he is experiencing. Most likely the frame mounted fuel filter housing is not tightened all the way is it's sucking air. Also check the yellow drain **** as it will allow air into the system as well if not tightened properly.
Old Jun 18, 2019 | 08:31 AM
Fefanatic's Avatar
Fefanatic
The key here is it happened after he changed filters. Go back and check his work. Most likely the frame filter cap isn't tightened to the stop.
Racmath
6.7L Power Stroke Diesel
Nov 4, 2018 05:45 PM
rlanicek
19
Feb 17, 2016 08:32 AM
oldgrasshopper
17
Jan 17, 2016 12:02 PM
EMC V10 X
Dec 7, 2014 07:09 PM
countrykid_86
6.4L Power Stroke Diesel
Aug 13, 2011 04:21 AM
