which is easier?
Old Jun 16, 2019 | 11:20 AM
dremtofford's Avatar
dremtofford
which is easier?
my rear tank fuel pump died on my 95 f-150 and i was wondering if it would be easier to cut the tops of the bolts holding the bed on or to drop the tank?
Old Jun 16, 2019 | 11:38 AM
sandymane's Avatar
sandymane
You can't remove the nuts under the bed? Sandy
Old Jun 16, 2019 | 11:40 AM
rla2005's Avatar
rla2005
Everyone has their opinion, I find it very easy to drop the tank. If you have 3-4 brawny friends then you may find pulling the bed easier. When I replaced the rear tank on my old 1992 F350 I dropped the tank to the ground using two ratchet straps. Took about 45 minutes.
Old Jun 16, 2019 | 11:44 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
Drop the tank, it is not hard with a good sized floor jack. I have done this with full tanks and empty ones.
Make certain to replace that o-ring seal between the tank and the sender with pump assembly! I did not once, had to drop the tank again.
Old Jun 16, 2019 | 11:46 AM
sandymane's Avatar
sandymane
I like RLA's idea. No buying beer for the help either. Also, I don't know how you could cut those carriage bolts without some play.
Old Jun 16, 2019 | 11:49 AM
animator's Avatar
animator
It's easy enough to drop the tank. I've done it by myself a couple times.
If there's gas in it, disconnect the line at the filter and jump the fuel pump to pump it out into a container. Once empty enough to move, drop it down onto a jack. I use a transmission jack, but it's light enough to lay under it and wrestle it out without tools once it's empty.
Old Jun 16, 2019 | 02:16 PM
jwernatl's Avatar
jwernatl
There's a video I just saw yesterday, w/ a guy pulling the bed back. He did all of this to change the pump in the tank The carriage bolts you talk about can be accessed from the bottom. The guy shows you where, gives size- its ac excellent video..
Old Jun 16, 2019 | 02:20 PM
Conanski's Avatar
Conanski
Cutting the heads of the bed bolts doesn't buy you anything if they are OEM because they also have a shoulder that clamps the lower surface of the bed frame to the chassis, so even with the heads completely ground away the bed still won't come off. Cutting off the bed bolts only works if they aren't OEM style or if you are trashing the bed and don't mind cutting away the bed around the bolts.
Old Jun 16, 2019 | 05:26 PM
dremtofford
the nuts and bolts are rusted solid so i have been soaking them with pb blaster and i found my 5 ft breaker bar the other day. so i shall try round two tuesday on my day off.
Old Jun 16, 2019 | 05:57 PM
My4Fordtrucks's Avatar
My4Fordtrucks
.....and that is why I drop the tank. It is much easier to replace a couple straps you had to cut than deal with what you now encountering.
Old Jun 16, 2019 | 07:43 PM
Nothing Special's Avatar
Nothing Special
I've done one tank, and with typical Minnesota rust it's definitely easier to drop the tank. But if you have a bunch of different things to do all at once (both tanks, maybe some rear axle work and/ot cleaning and painting the frame) it might be better to pull the bed.
The trickiest thing I found about dropping the tank was getting the gas lines disconnected. It was the first time I'd done that style. You need the right tool, and it needs to be for the correct size line. And the supply and return lines are different sizes. And the first cheap tool I bought didn't work... And of course I was doing all of this with the tank on a floor jack, trying not to let it get down too far so it was hanging from the lines. Overall not that big of a deal, but that was the part of the job that I started to wonder if it would've been better to pull the bed (but ultimately decided I had done it the best way).
Old Jun 16, 2019 | 07:44 PM
Conanski's Avatar
Conanski
Then don't waste your time, if you do manage to turn the bolts you will break the captive nuts away from the frame so they just spin. The only way your bed is coming off is with a sawzall or torch.
Old Jun 19, 2019 | 07:13 PM
Roger T. Pipe's Avatar
Roger T. Pipe
It depends on how much fuel is in the tank...if it's more than 1/2 it may be a little difficult to drop it. I'm of the "pull off the bed" school...that way you can always check on the condition of the frame rust-wise and see whatever else is happening there.
If the bed bolts are stuck, simply weld a nut on top of the head of the bolt and have a helper stay there holding a wrench on the bolt. Ideally, you'd want to replace the bed bolts with factory pieces, but from what I hear, they're prohibitively expensive.
John SCB
15
Mar 7, 2012 07:54 PM
mustang68s
May 17, 2010 01:41 PM
Farmboy1285
Nov 16, 2009 08:55 PM
Silentst2000
Feb 8, 2006 02:46 PM
why165
Jun 11, 2005 10:24 AM
