Just questioning about how much of a vacuum reading I should look for when tuning 351m bored .040 over 4bbl carb and a cam for an rv. Thanks in advance
GENERALLY, want to see 18" to 20" steady needle at a factory idle RPM of 500 to 600. This is the standard for a stock engine, in good mechanical condition i.e. compression rings, valves etc., at sea level.
If living at altitude, 15" or 16" steady might be the best that can be achieved. Once a performance type camshaft enters the mix it gets tricky. The long duration overlap means a lower overall manifold vacuum. Might see something around 8" Hg.
The mechanic's vacuum gauge is practically an indispensable tool, all kinds of engine derangements can be diagnosed with a little user experience, maybe 20 to 25 different defects or tuning faults from late ignition timing, to valve problems, carburetor misadjustment, exhaust restriction and so on. Also measures mechanical type fuel pump pressure output, another important tune-up or replacement check.
