Eastwood's Single Stage Paint
For what Eastwood wants go to TCP Global and get the same paint. I think even Kirker single stage is a better paint with more options and better flow through cheaper spray guns. At the end its still SS and for not much more just spray two stage. It's up to you but a good base with a 2k clear will be more durable and provide a thicker finish.
What two stage system.do you recommend primer, paint and clear?
I use a lot of the Kirker products, price is right and finish is good. Also find its slightly easier for a novice. I have done 25+ trucks and trailers with their products. I use HOK or Dupont on the more expensive projects.
Click here
Click here
brcwelding
11-19-2011 06:11 AM
