Camshaft upgrade
Old Jun 12, 2019 | 10:16 PM
VictorLaw's Avatar
VictorLaw
Camshaft upgrade
I have a 1995 F-150 351w(roller) e4od
I pulled the motor because the I thought I had a few lifters tapping and I wanted to replace the seals around the engine because of leaks.
My cam is shot and I was looking to upgrade, everything is stock on the engine I’m looking for a cam that will work with my stock heads and lower end.
I will be replacing the camshaft, lifters, rocker arms, pushrods, valve springs, and valves.
thanks
Old Jun 13, 2019 | 07:04 AM
trendyvan's Avatar
trendyvan
i have a stock roller 5.8 cam I put a Lunati in mine,just pay shipping and its yours I also have a new timing set Cloyes chain Id throw in for 5 bucks more
Old Jun 13, 2019 | 01:25 PM
VictorLaw's Avatar
VictorLaw
Is it new or used?
also what lunati cam? I was thinking of upgrading but I know there’s some issues with SD trucks
Old Jun 13, 2019 | 04:17 PM
trendyvan's Avatar
trendyvan
Stocker a few folks like them with
just longer rockers I got a Lunati 20350614
Old Jun 13, 2019 | 05:17 PM
torq'ta 5 8's Avatar
torq'ta 5 8
his stock cam probably came out of his for Lunati to go in, when you say upgrade,how many miles on it? what is budget $$$, verses your goal, lots a ways to skin a cat
Old Jun 13, 2019 | 07:32 PM
Scndsin's Avatar
Scndsin
Wouldn't do anything yet since your bearings in the lower end has high probability of metal embedded in them.
Just an observation, mind you, but that tool steel ground up metal from the roller washed down the insides of your engine long before it got to the filter.
Old Mar 29, 2021 | 08:00 AM
DaveMcLain's Avatar
DaveMcLain
I've got a book on camshafts by Don Hubbard and a similar drawing showing where pits are allowed and where they aren't is the same. The loading on the base circle is really low so it just doesn't matter if the pits are smaller than a certain size. For cams used in non production applications where they will be seen most of the time they don't allow any pits simply because looks matter.
MR KROGOTH
Mar 5, 2016 10:31 PM
mpc07005
Jul 17, 2012 09:09 PM
CLIFF1989
Mar 7, 2010 04:51 PM
austynn2001
Aug 27, 2006 12:43 AM
ScottJM
Feb 16, 2005 11:52 PM
