AC whistle
Old Mar 28, 2021 | 12:29 PM
Freggles's Avatar
Freggles
AC whistle
So, before I get hounded for not searching, I have looked at many threads that sound similar but none address the issue I am having.
when I turn on my AC with either of the A/C settings on the dial, there is not cold air, but more concerning for me is the sound that accompanies this. There is a whistle that comes from the vents I dependent of speed. In park or on the highway it is the same. This whistle is not constant. It comes for a few seconds and is gone for a few more. It is not rhythmic, but rather random timing. Almost sounds like a dog begging at the table. I have not been running the AC as a result this. I want to take it to a mechanic but I’m curious what to expect and/or see if there’s anything to check first. I will post up a video today so you can hear for yourself. Thanks in advance.
the truck is a ‘93 XLT 2wd 5.8L
Old Mar 28, 2021 | 12:41 PM
R&RFord's Avatar
R&RFord
Check to see if the ac is coming out of the defrost vents.
Old Mar 28, 2021 | 12:59 PM
Freggles's Avatar
Freggles
The air comes out of whichever vent is selected but it is not cold at all
Old Mar 28, 2021 | 02:57 PM
Thejackalope's Avatar
Thejackalope
Remove your blower motor and check the cage for damage.
Old Mar 28, 2021 | 04:44 PM
Freggles's Avatar
Freggles
Will do. Thanks!
Old Mar 28, 2021 | 07:03 PM
Thejackalope
Also, when the blower is out check the evap for blockage. The fact that the a/c is not blowing cold may or may not be the same issue. If your compressor is engaging you may have an issue with the blend door which could case both symptoms you are having also.
Old Mar 28, 2021 | 11:42 PM
Freggles's Avatar
Freggles
this is in park by the way
here’s what it’s doing
Old Mar 29, 2021 | 08:03 AM
R&RFord's Avatar
R&RFord
My fist guess is that there is a vacuum leak in the cab. The system uses a combination of electrical and vacuum systems, so there is a fair amount of vacuum tubing, connections, motors, and the switches that could be leaking.
One way to confirm or deny would be to disconnect the vacuum feed line from the intake manifold, cap the port on the manifold, and see if your whistle is gone.
Pronto285
20
Jun 14, 2020 03:35 PM
MyBoyBlue78
2009 - 2014 F150
May 18, 2014 09:32 PM
brian1253
6.4L Power Stroke Diesel
Aug 13, 2013 11:10 AM
Barndon
Aug 12, 2010 11:11 PM
b8blcrazy
2004 - 2008 F150
Mar 15, 2005 03:43 AM
