Brake Light On The Dash ?
Old Jun 12, 2019 | 06:57 PM
Arsoncop's Avatar
Arsoncop
Im redoing a 73 highboy and chasing some electrical gremlins around in the system. The issue right now is the emergency brake light stays on. The truck had awful brakes so I replaced the entire brake system except the master cylinder and booster. I have bled the system three times and gotten the soft pedal out. There is no switch on the Ebrake. Whats up ?
Old Jun 12, 2019 | 07:06 PM
ford390gashog's Avatar
ford390gashog
These trucks don't have a light for the parking brake. The light is for the brake pressure differential valve. It's a sure sign it's not centered and you still have air in the system.
Old Jun 12, 2019 | 07:31 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C8AZ-2B264-A .. Brake Pressure Differential Valve Warning Lamp Switch / Obsolete - Available NOS & from auto parts stores.
This switch threads into the valve (some peeps call it a proportioning valve), located below the master cylinder on the frame rail.
Applications: 1968/69 FoMoCo Passenger Cars // 1968/79 F100/350, Bronco & Econoline.
Old Jun 12, 2019 | 07:51 PM
ford390gashog
Wouldn't it be incorrect when people refer to it as a proportioning valve? These trucks were four corner drum and the differential valve is just to show when system pressure isn't equal. The trucks with disc brake did use a 60/40 proportioning valve.
Old Jun 12, 2019 | 07:57 PM
Arsoncop's Avatar
Arsoncop
So I guess I need to look into replacing the switch on the valve and bleeding again
Old Jun 12, 2019 | 08:02 PM
NumberDummy
See 2B257 in pics. 15A851 is a parking brake signal light switch only used on 1979 E350 Super Van/School Bus (D9UZ-15A851-A).
Old Jun 12, 2019 | 08:58 PM
tabascom16's Avatar
tabascom16
If you take out the electrical part of the brake pressure switch from the proportioning valve there is a little "shuttle" that moves. It has a detent that will engage the switch and light up the light on your dash. You may need to take a tiny screw driver to move it back to center. It often does not return on its own when just bleeding the brakes.
mccolalx
Sep 18, 2015 11:12 PM
Clefox4
Mar 27, 2015 09:15 PM
jake_c_19
Jan 11, 2014 06:54 PM
M. P. Gray
Dec 19, 2009 04:24 PM
1968stepside
Feb 4, 2004 11:01 AM
