Brake light staying on
Old Jan 11, 2014 | 02:33 PM
jake_c_19's Avatar
jake_c_19
Few days ago while I was applying the brakes the brake like above the dash come on and will not go off it is the same light that comes on when I put on the parking break. Is this an indication of a brake problem?
Old Jan 11, 2014 | 03:08 PM
quakerj's Avatar
quakerj
It can be. Did you notice anything unusual when the brake light came on?
Mine came on when my master cylinder started to go bad. One of the seals was bad, so one side would work (front or rear) while the other side lost pressure.
When one side loses pressure, the high pressure side moves a plunger that closes off the side with the failure to prevent fluid loss and complete brake failure. When the plunger moves, the switch is opened, turning on the light. Once the switch is triggered, it has to be reset.
On mine, the electrical connector was the switch. It could be turned out by hand. Once the switch was out, the valve has to be centered. This can sometimes be done by pressing on the brake pedal REAL hard. More often than not though, you have to open up one of the bleeders on the side opposite of that that had the problem and bleed those brakes. This will create a pressure differential that will try to move the valve to the side that's open. Once the valve is centered, thread in the switch and the light should be out.
If the problem persists and isn't fix, it will just set the light again and you'll have to keep repeating this process. The brake light shouldn't come on on it's own, it's always indicative of a problem in the braking system.
These things are a pain sometimes, because the plunger tends to stick after 20-30+ years.
Old Jan 11, 2014 | 05:07 PM
reamer's Avatar
reamer
You're talking the switch on the proportion valve correct?
Old Jan 11, 2014 | 05:11 PM
Franklin2's Avatar
Franklin2
If you want to see if it's the switch on the proportioning valve, simply get under the hood and pull the wire off the valve. If the light goes out, then yes it was the proportioning valve switch and yes, that means you have a problem in the braking system.
If that didn't make the light go out, then reach down and pull up on the parking brake pedal. If it goes out, then you need to mess with the parking brake mechanism.
Old Jan 11, 2014 | 06:54 PM
ctubutis's Avatar
ctubutis
This isn't true, from where did you get this information?
The Ford shop manual says nothing to that effect and in fact describes it entirely differently, and the cross-sectional drawings don't depict such functionality being possible... the front & rear are two independent systems, a leak in one system will continue until the reservoir is empty (yes, the pressure differential will ultimately cause the dash light to be lit by the plunger in the switch being grounded, not opened) but, barring a problem on the other side, the other half will still work.
From the 1981 FoMoCo Light Truck Body/Chassis/Electrical shop manual (FPS 365-326-81-A):
flowney
Dec 10, 2017 07:57 PM
Floggit
Mar 29, 2015 02:14 PM
M. P. Gray
Dec 19, 2009 04:24 PM
Ford51
34
Dec 11, 2006 02:18 PM
paulpatter
19
Aug 25, 2006 10:34 PM
