Sponsored by: Real Truck
trailer connector mount.
Old Jun 12, 2019 | 02:51 PM
pbsdaddy's Avatar
pbsdaddy
The trailer wiring connector mount has rusted out on my F250. Now the connectors are just hanging there. It appears the connectors can easily be removed as there is a simple clip on the back. However, I have not been able to find just the sheet metal mounting bracket. The only thing I have found is a complete bracket with both the 4 and 7 pin connectors already installed. Has anyone needed a new bracket, bought just the mounting bracket, or am I doomed to pay nearly $60 for a piece of sheet metal?
Old Jun 12, 2019 | 05:16 PM
Just Strokin's Avatar
Just Strokin
Go to Lowe's or Home Depot. They have small pieces of heavy gauge sheet metal for reasonable cost.
Old Jun 12, 2019 | 07:55 PM
jimzdat's Avatar
jimzdat
Mounting Brackets
My local parts store carries some of these - if you have a Rural King/Tractor Supply near by, they probably will too. Might require some minor fabrication, but a lot cheaper than the dealer....
Old Jun 13, 2019 | 04:21 AM
pbsdaddy's Avatar
pbsdaddy
Thanks Jimzdat. That's what I needed. to know.
Old Jun 13, 2019 | 03:24 PM
Sam I Am's Avatar
Sam I Am
I like these
https://www.etrailer.com/Custom-Fit-...s/HM40975.html
Old Jun 13, 2019 | 05:57 PM
pbsdaddy's Avatar
pbsdaddy
Originally Posted by Sam I Am
I actually like that myself. I wonder, (I could not find a direct answer), if the factory wiring will plug into their receptacle?
Old Jun 13, 2019 | 11:19 PM
Sam I Am's Avatar
Sam I Am
If your truck has the modular connector on the truck side of the 7 pin, then yes it is universal.
There are a lot of pictures on that link so make sure yours matches. E trailer has pretty quick customer support answers, but you should be able to look at what you have on your truck to make sure it matches with that piece. That exact 7 & 4 connector was actually original equipment on cab and chassis Fords for a while. You might find some "new" take offs on ebay cheaper.
Also some people have been known to Dremel cut the mounting slot in their bumper to fit that 7 & 4 receptacle into the bumper without the bracket.
Old Jun 14, 2019 | 06:07 AM
pbsdaddy's Avatar
pbsdaddy
Thanks. I saw their Q&A section and sent a note, asking if it was a direct plug in. Just got an auto-response saying I would receive a response soon. That is quick service.
CSDenny
Jul 7, 2024 08:45 AM
pjviitas
All Things Towing
Mar 6, 2016 11:19 AM
bigred66
Oct 27, 2014 09:47 AM
rwhite07PSD
Jul 24, 2009 11:06 AM
eclectix
All Things Towing
Jun 22, 2003 12:16 AM
