Turn Signal Switch
Old Jun 12, 2019 | 12:46 PM
HVFDFIREFIGHTER1618's Avatar
HVFDFIREFIGHTER1618
Turn Signal Switch
I have installed the following turn signal switch. My problem is that the red indicator light on the steering column switch is on when switch is off (middle position) and indicator light is off when switch is on (lever up or down or hazards on). The wire that comes from the flasher (x) goes to power. Should this power be the RAD post on the ignition? Maybe I have the gray/black wire to the stop light switch reversed. Any help would be appreciated.
Old Jun 13, 2019 | 10:42 AM
bobj49f2's Avatar
bobj49f2
I think this might help. Most switches are wired the same way.
Old Jun 14, 2019 | 06:45 AM
g-money-55's Avatar
g-money-55
Thank you for posting this. Being a visual person this was great!
Greg
Old Jun 14, 2019 | 11:26 AM
r_reed's Avatar
r_reed
i think mine acted like that when my ground wire was sketchy. not 100% sure.
Old Jun 16, 2019 | 12:02 AM
electricmaniac's Avatar
electricmaniac
Guys -
Thank you FireFight and Bobj for the drawings. Very informative.
I cannot get the little green indicator lights on the unit to work. I am sure the bulb is good.
Everything else works just fine.
Would the problem be something with the ground?
(I know, I know, the guy's name is electricmaniac and he cannot figure this out? Its a long story.)
Old Jun 16, 2019 | 11:16 AM
bobj49f2's Avatar
bobj49f2
Ground plays a huge factor in these six volt systems. Also check to see if the bulb is 6 or 12 volt. I have a 12 volt bulb in mine and it doesn't work. Just haven't looked for a 6 volt bulb.
Old Jun 16, 2019 | 11:36 AM
electricmaniac
Thanks Bobj. Ran a wire from the strap that holds the unit to the column over to a good ground to see what might happen.
Green eyes light up! Need to scratch a bit of paint away where strap mounts on column, or use a star washer, or something to get good ground.
I would have thought green indicator lights were wired up through the turn lamps circuits. I guess not.
Old Jun 18, 2019 | 06:19 AM
HVFDFIREFIGHTER1618
My dash panel had two holes covered with tape for left and right turn indicator lamps. I installed two light sockets. Both worked for left, right, and hazard indicator as should. This was with dash out of panel. Turned ignition on, light switch on and high beams on and the left light blinked for the right turn and the right turn blinked for left turn. Turned high beams off and the indicators went back to normal. Then I started to notice that the two dash lights were blinking along with the turn indicator. Then I held the dash against the metal part of the brake pedal (ground) and all seems to be OK. Hopefully tonight, I will get the wiper motor and wiper switch installed, get the dash in, and see what happens then. I ran the indicators off of the turn signal wires for the front turn signals.
I'll keep everyone posted.
Thank you all for the help. I don't know how I could have taken this whole project on without all of you and this wonderful website!
abe
Oct 5, 2017 02:02 PM
johnr9q
Electrical Systems/Wiring
May 21, 2015 11:20 AM
celtic11
Apr 28, 2013 03:37 PM
alex76-f250
Jan 11, 2010 11:39 PM
GeneStoner
Apr 28, 2004 11:06 PM
