Radiator Adaption needed
Old Jun 11, 2019 | 09:23 AM
Jared20burks's Avatar
Jared20burks
7th Gear
I have a 96 powerstroke that I adapted into a 92 idi body and frame and I'm having issues with finding a radiator that'll fit the frame on the 92 is about 4in narrower. Had anyone done anything similar and know about a radiator that will work? Reason being I dont use the idi one is it's bad and the replacement that fits is 6-800 dollars
Old Jun 11, 2019 | 09:32 AM
ford390gashog's Avatar
ford390gashog
The frames are the same width. It's the core support that's your issue, the IDI trucks had a small radiator option for trucks with no air conditioning. Post a picture of the radiator you currently have. The more common radiator is available from Champion for under 300.00 delivered.
Old Jun 11, 2019 | 09:35 AM
Jared20burks
7th Gear
They are not the same width, and the one you're talking about is the one that's special order only and 6-800
Old Jun 11, 2019 | 09:48 AM
ford390gashog
Front frame is the same width not sure where you are measuring from.
Old Jun 11, 2019 | 10:00 AM
Jared20burks
7th Gear
Old Jun 11, 2019 | 11:30 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
Why not just rebuild the radiator you have currently?
Old Jun 11, 2019 | 02:29 PM
quesey's Avatar
quesey
What does the rest of that frame on top picture look like ?
Old Jun 11, 2019 | 07:26 PM
quesey's Avatar
quesey
Looks like a early frame
J.Boyea518
1978 - 1996 Big Bronco
Apr 8, 2016 10:36 PM
xjpilot
Dec 10, 2013 08:06 AM
lemonshindig
Dec 4, 2013 09:13 PM
deisele75
Jul 16, 2005 01:14 AM
frankydabull
1947 and Older Ford Trucks
Mar 8, 2004 06:14 PM
