Question on 2004 Hpop
Old Jun 10, 2019 | 03:25 PM
Visurveyor's Avatar
Visurveyor
This is a picture of the top of my 2004 Hpop.
look at the two bolts. They're different. Should I be concerned on this. I am getting my hpop tomorrow be ready to install. As far as I know from my dad who gave me the truck before he passed, no hpop been put in this truck. Am I overthinking it, or should those bolts be the same.
Thanks for your insight as always
Old Jun 10, 2019 | 03:45 PM
TooManyToys.'s Avatar
TooManyToys.
As long as they are the same strength and length, I would not worry. The strength will be labeled something like 10.2. Just check length when you pull each.
International apparently used several suppliers of bolts. With my reman motor, they are distributed all over the place, but it may have been the same with the original build.
Old Jun 10, 2019 | 03:52 PM
Visurveyor's Avatar
Visurveyor
Thanks i will go out and look. Didnt want to tear all the way down until pump arives less open surfaces, and its fresh on mind out and in. Thanks again Toys.
Old Jun 10, 2019 | 03:53 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
They should be the same, you can get the bolts from the Ford dealer along with the o-ring kit for the discharge tube you see there, below the discharge tube, and below the pump itself. They're color coded so it's hard to mess up.
Old Jun 10, 2019 | 04:15 PM
Visurveyor's Avatar
Visurveyor
Have the oem set for Hpop, turbo and egr just couse i have it open. Oil cooler was done 3 months ago by not so good shop so am going over every thing.
Colorado350
41
Dec 19, 2018 06:10 PM
beemr
May 20, 2013 05:54 PM
GruesomeJeans
1978 - 1996 Big Bronco
May 4, 2012 12:05 AM
dickys79
Dec 7, 2010 11:23 PM
Whilly
Mar 5, 2004 11:03 AM
