1997 IDM Connector question
Old Jun 10, 2019 | 03:23 PM
Bigfoot0220's Avatar
Bigfoot0220
Hello all. A couple months ago I got some help on here getting my 97 350 started. Turned out to be a bad IDM. Put the new one in and it started and ran good for a month or so. Started one day and it idled rough until I gave it some gas, then it smoothed out. Another time it cranked but would not start. I jiggled the wire harnesses and then it fired right up. After it was running, I found that if I just barely touched the power lead (green wire, pin 14?) right where it enters the connector the truck would just shut off but would start right back up. Over the next couple weeks it was mostly fine, a couple times it just cranked and I could get it going by playing with the wire. This weekend it shut off while driving and I couldn't get it going again. Towed it home and now figuring out what to do. I think I fried the IDM by having a short in the wire. I've done a lot of looking and so far cannot find any used harnesses, so my question, is there any way to repair the pin connection at the connector? I'm confident that the problem is at the power wire but inside the 26 pin connector and can't figure out how to fix it if I can't find a whole new harness. Ford doesn't sell it (would probably bankrupt me if they did).
The picture below isn't from my truck, just found it online, but it shows the connector I'm talking about and the green wire which seems to be the problem. Any help would be greatly appreciated. Thank you.
Old Jun 10, 2019 | 03:36 PM
knottyrope's Avatar
knottyrope
https://www.ford-trucks.com/forums/1...load-test.html
Wiring diagram in above link
maybe a junk yard will have the cable
Ebay has some harnesses for sale
Old Jun 10, 2019 | 03:50 PM
TJLongworth's Avatar
TJLongworth
I have 3 obs ford harnesses, the only issue is that they are not complete... all 3 have good idm connectors though. Ill check to make sure when I get home
Old Jun 10, 2019 | 04:22 PM
Bigfoot0220
Wow, that would be awesome. Complete isn't necessary, I just need the connector and splice away. Sold!
Old Jun 10, 2019 | 09:30 PM
fordpride's Avatar
fordpride
You can re pin them. Look up Molex pins
Old Jun 10, 2019 | 09:31 PM
fordpride's Avatar
fordpride
Don’t chop up your harness is you don’t have to
Old Jun 11, 2019 | 07:30 AM
TJLongworth
I pulled the harnesses off the mezzanine and all the pins are loose-ish in the connector,
I can still cut it off for ya, but I didnt even think of repining them, Thats a much better idea
Old Jun 11, 2019 | 12:24 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
What size are needed for the PCM plug? I need a few for mine.
Old Jun 11, 2019 | 07:31 PM
fordpride's Avatar
fordpride
I’m on vacation right now. I can’t remember off the top of my head. It’ll be Monday before I can look at my harness to tell you a size.
Old Jun 14, 2019 | 11:17 PM
Bigfoot0220
Ok, so now i'm really stumped. I removed the PCM connector, IDM connector, and the square 42 pin connector to inspect wires, didn't find anything wrong. I put everything back together and went to crank, and nothing. No radio, HVAC, headlights, nothing. It was like the batteries were completely dead, but they check out fine. I even jumped the ignition relay and engine cranked just fine. Checked all fuses, none blown. What could have happened? Is there a fusible link I don't know about that could have shorted? This is going downhill fast, and I'm starting to feel completely defeated.
Old Jun 15, 2019 | 04:01 PM
Bigfoot0220
Alright, I got the power back to the cab, and I'm back to a crank no start condition. I did buzz test, no issues. DTC's that came up were P0472, P1754, P1705, none appear to be relevant to the no-start, but maybe I'm wrong.
I checked all IDM pins according to the guides, all 3 tests checked out normal. I'm leaning towards another IDM, but if that's the case I don't know why this one only lasted a couple months.
DrCharles
Dec 29, 2017 06:05 PM
KevinPC13
Sep 12, 2015 01:42 AM
JRSutton
18
Sep 11, 2012 11:07 AM
jtexfisher
Apr 19, 2011 03:25 AM
jemini
Nov 12, 2007 09:22 PM
