Update on my electrical issues.
Old Jun 10, 2019 | 01:20 PM
Motohead911's Avatar
Motohead911
Well a little update on my latest adventure with this truck. As I discussed in a different thread I spent a couple days chashing CAN comms issues. Which of course lead to deeper problems.
What started this was me loading a new tune into my truck. In talking with the tuner and follow the Workshop Service Manual I narrowed it to the PCM. I then talked with Ed at ficm repair and he helped me look at the charging system.
Now on the latest advice, tested the batteries, while a little low they still tested.ok. Now i.looked.at.my charging system. May have found the smoking gun (fingers crossed). I have a dual altnerator system on my truck which I think hid the issue. I just took the second alternator out of the system per Ford.Bulletin Q-91. And after the truck is warm, when I load tested test the alternator it is in the mid 12s at low idle and high 12s at high idle. So now I have ordered a new Bosch AL7606N 140 amp alternator to install.
I still need a new PCM but it works right now though it did finally throw a P0606 code. Also, I need to get the FICM tested, it it will probably be my next issue.
So the saga continues...
Old Jun 10, 2019 | 01:40 PM
bismic's Avatar
bismic
P0606 could easily be ONLY due to the alternator.
Old Jun 19, 2019 | 02:22 AM
Motohead911
Confirmed with IDS the PCM is busted. Time to get a new one.
Old Jun 19, 2019 | 03:27 AM
bismic's Avatar
bismic
Sorry. That isn't common.
cpye2
Dec 21, 2015 01:48 PM
trike1946
Electrical Systems/Wiring
Oct 3, 2012 05:34 PM
Sarge261
Aug 27, 2012 02:13 PM
Mike Cavalier
Feb 3, 2012 10:38 PM
PsD007.3
18
Apr 9, 2009 09:52 AM
