heater core question?
Old Oct 4, 2003 | 03:41 PM
Martys82's Avatar
Martys82
ok, i found a heater core/ fan motor..well the whole housing. says its from an 85 f150
it says high output on it and i have 82 f100 and mine does not say high output on it... will this work?
Old Oct 5, 2003 | 04:47 AM
Jens's Avatar
Jens
Hi,
if the core has the same size......why not.
I think it's not a problem.....
Jens
Old Oct 5, 2003 | 10:55 AM
84ford460's Avatar
84ford460
Is your truck equipped with A/C or not? The only time I have seen the High Output setup is on vehicles not equipped with A/C. As long as the two setups are the same, IE air or no air they should bolt right in.
I changed out my truck from A/C to no A/C. I used all the parts that I needed from a donor 83 truck. It was kinda a pain in the you know what.
You shouldn't have any problems though.
Good luck!
Larry
1984 F250 4x4 w/460
Old Oct 5, 2003 | 02:29 PM
Martys82's Avatar
Martys82
yea i dont have ac, so im hoping this works..
Old Oct 5, 2003 | 06:46 PM
kermmydog's Avatar
kermmydog
If the core fits the housing & the inlet & outlet fit through the firewall you're home free.
Drac
Dec 20, 2011 10:15 PM
Mudman
Mar 25, 2007 05:08 AM
towtruck1
Dec 7, 2006 10:59 PM
gingerbreadmaniac
Sep 21, 2004 03:11 AM
Shannonm1
Jan 18, 2004 02:58 PM
