Bilstein Shocks Advice
Old Jun 9, 2019 | 07:08 AM
WA_PSD's Avatar
WA_PSD
New to the F-150 world and love my new (used) truck. I do wonder with my setup if I could get a better ride loaded and unloaded. Both are decent now, but I did hit a bump on the freeway last weekend on an overpass corner and kinda hopped, was little puckery. I have a 2” spacer up front I was told and 285x75x17’s running about 36 psi.
On my previous Super Duty’s I added both bilsteins and Rancho 9k’s. I would like to add Bilstein 5100’s like my last truck but am a little confused with online shopping. Are the fronts struts instead of shocks? I just thought I could slap on some shocks, what’s the difference. I have never had struts, just older Super Duty’s with shocks. I know I could just google and find out most info, but reading these boards daily I know I will get the best answer for what i’m looking for on this decision. Thanks
Old Jun 9, 2019 | 07:23 AM
WA_PSD's Avatar
WA_PSD
Also, not sure why my signature isn't showing up so it shows my rigs details? I have it added in edit signature, looks correct and saved.
Old Jun 9, 2019 | 08:07 AM
GABAR's Avatar
GABAR
The fronts are considered struts but depending on who one is talking to, many people just call them shocks and many websites will list them as shocks.
With that being said and you might know this already, the fronts are much more difficult to change than the rear because the actual coil spring goes around the front strut / shock like a coil over and one must use a spring compressor to change them.
I hope this info helps you out.
Old Jun 9, 2019 | 08:08 AM
windellmc's Avatar
windellmc
Struts in front and shocks in back. You will get the biggest bang for your buck doing the backs and they are easy to install.
Old Jun 9, 2019 | 08:31 AM
WA_PSD's Avatar
WA_PSD
EXACTLY what I was looking for, thank you guys. I'm gonna get the rears first and see what how it goes. Just watched a youtube on the install, SUPER easy 1 beer job.The dude even said the 5100's even helps with rear tire hop
Old Jun 9, 2019 | 08:39 AM
sddesigns's Avatar
sddesigns
FTE Leadership Emeritus
FTE Emeritus
Yes, they are coil over struts in the front, you can buy a pre-loaded strut or just a strut and will require a spring compressor to remove the coil. This will also allow you to level the stance or leave it at the current setting.
Old Jun 9, 2019 | 10:24 AM
windellmc's Avatar
windellmc
The wheel hop is coming 100% from the rear shocks. I used 4600 on the rear and it took all the hop away. Your front shocks are probably bad too but the fronts wearing out is very subtle and most people don’t notice or care what is going on with the front and any handling issues due to the front wearing are minor.
cuda66
Mar 13, 2014 01:34 PM
soos76
1997 - 2003 F150
May 10, 2009 07:52 AM
Shanemh
Nov 8, 2006 09:48 PM
wizzard351
Offroad & 4x4
Jan 13, 2006 07:52 AM
MrDeath8666
Dec 28, 2003 04:06 AM
