Bad intake gasket?
Old Jun 7, 2019 | 08:41 PM
OBSTommy17's Avatar
OBSTommy17
Bad intake gasket?
So I have a 1989 crew cab dually 7.3 idi turbo with C6 auto, I noticed about a month ago a lip coooant missing so I filled it up and then today I noticed a oil bit more missing so I found coolant around the cap of the oil fill but none on the dipstick,then I removed air cleaner and found oil laying in the bottom of there. The truck is running the same, but I have noticed it doesn’t not smoke black hardly as much as it used to when I get on it. The radiator had no oil in it so I think that elimantes the head gasket, and the tranny fluid was fine so I think that eliminates a leaking cooler line. So all that’s left is just the intake manifold gasket right?Thanks in advance
Old Jun 7, 2019 | 08:53 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
IF you have water on the Oil Filler Cap then it ain't the Intake Manifold Gasket.....
there is several things it could be..... it could be the oil cooler.... it could be Head Gaskets or Head... or it could be the Block.
Do you test your coolant SCA ?
since you are loosing Coolant it would seem that it is not Condensation
Old Jun 7, 2019 | 08:59 PM
DarkOverCast's Avatar
DarkOverCast
There's no coolant passages in our intake gaskets.
Most likely cause is oil cooler orings putting coolant in the oil which probably steams and ends up on the oil cap and passes through the cdr to end up in your intake. The intake is really flat so it's bad about pooling up in there.
Old Jun 7, 2019 | 09:09 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Yeah ^^^^^^ what he says... first place I would look, the oil cooler.... but I think we all know what water intrusion generally means
another good test is run it 20 or so miles then in the morning pull the Glow Plugs and have a look see.....
Old Jun 7, 2019 | 09:10 PM
OBSTommy17's Avatar
OBSTommy17
So is this something to worry about? Is it okay to keep driving? And how would I go about fixing it, thanks
Old Jun 7, 2019 | 09:11 PM
OBSTommy17's Avatar
OBSTommy17
What would it generally mean?
Old Jun 7, 2019 | 09:23 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
ok I assume this is the original engine.......... next in my first post to you was is Do you test the SCA ... Coolant test strips as these engines are prone to Block Failure if the coolant system is not maintained properly. this is what I generally mean
Old Jun 7, 2019 | 09:33 PM
OBSTommy17's Avatar
OBSTommy17
Yes it is original engine and barely over 104,000miles, and no I do not usually test the coolant,I live in California where it doesn’t get very cold so I just always put 50/50
Old Jun 7, 2019 | 09:50 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
As was mentioned, check out your oil Cooler first..... and to understand more about SCA search Diesel engine Cavitation
I'll give a quick link for our 7.3 Diesels ..... Understanding Cavitation in the 7.3L IDI Diesel
back in the old daze we used to use Water Glass in our engines probably rare to find it today (sodium Silicate) but it was a stop gap method that worked back then.
I'm not trying to say that you have this issue, but only trying to make you aware that it does in fact exist and you can do things to prevent it.
Old Jun 7, 2019 | 10:12 PM
OBSTommy17's Avatar
OBSTommy17
Yes I have heard about the 7.3 cavitation but thought it was rare, I’ll get some strips and then check out the oil cooler and see what I find, I appreciate the help
Old Jun 8, 2019 | 08:13 AM
tjc transport's Avatar
tjc transport
i ain't rite
i really really doubt he has cavitation issues since the truck starts and drives fine.
if it had cavitation it would hydrolock after sitting and not start.
clean the top of the engine and start it up. look closely at the thermostat area for leaks. i bet you will find a small coolant leak around the thermostat. could also possibly be a coolant hose with a small leak.
Old Jun 8, 2019 | 01:48 PM
DarkOverCast
This. Cavitation is rare, yet alone below the travel of the piston, which would technically be repairable with a welder.
I've seen 7.3's with cavitated oil cooler ends where they'll **** coolant out yet the sleeves were fine.
I'd definitely start with resealing the oil cooler if you find it in the oil. You should drain it and check for water after letting it sit over night. Not recommend to drive
Old Jun 8, 2019 | 02:23 PM
Macrobb's Avatar
Macrobb
Correct, but there are coolant passages in the heads that get blocked off by the intake gaskets. Late model IDIs have plugs in the head in this spot. Early ones(88 at least) have just open holes that are sealed by the intake gasket.
That being said, I'm not sure how likely an intake gasket is to leak, usually they are pretty well sealed when I take it off.
Old Jun 8, 2019 | 09:38 PM
big ole ford's Avatar
big ole ford
You said you havea turbo on it correct? Have you recently had rain in your area? The reason i ask is when i bought my crew cab it had a problem with getting condensation on the dipstick and oil cap during wet weather and it came out to be the seal in the intake manifold valley pan where the turbo oil drains back into the engine, the seal had rotted out and was completely gone. I replaced that seal and no more condensation. Might be worth a look and its a cheap fix if that turns out to be the problem.
Old Jun 8, 2019 | 09:58 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
the oil cooler is really the first place I would look, IF you have water in the oil JMHO
BTW you can look at this post ... seems like a good thing... https://www.ford-trucks.com/forums/1...re-tester.html
the Machine shop I use is Burton Industrial they used to do Radiators too and they have the equipment to Pressure test these oil coolers, not sure how easy it is to find a shop that can test in other places.
