Weight Distribution Hitch?
Old Apr 24, 2006 | 09:55 PM
Ace!'s Avatar
Ace!
Are all receivers the same, or are there weight distributing ones? I have no knowledge of towing, so I'm wondering if the stock receiver has to be a weight distributing one or if the weight distribution comes from the trailer hookup????
Old Apr 25, 2006 | 01:23 AM
SoCalDesertRider's Avatar
SoCalDesertRider
The reciever hitch mounted to the truck can be used with or without a weight distributing hitch system.
The weight distribution system consists of a special ball mount that slides into your truck's reciever and has mounts beneath the ball mount platform for 2 large spring bars that extend back under the trailer a-frame and connect, via chain links, to 2 clamps that are mounted on the sides of the trailer a-frame. When you connect up the spring bars and pull the clamps tight, then set the trailer down on the hitch ball, the spring bars help carry some of the tongue weight. Because they are stiffly mounted to the truck via the reciever hitch, they transfer some of the tongue weight to the truck's front axle and some back onto the trailer axle too. This is 'distributing' the weight, and helps the truck to stay level with the trailer connected. The weight distribution system also helps keep the truck and trailer from 'porpoising' when crossing dips in the road.
Part of the weight distribution system is also usually included a sway control bar, which is basically a long shock absorber that connects from the ball mount to the trailer a-frame, that dampens side to side movement of the trailer, helping to keep it in line behind the truck instead of wanting to wag around. This is good for high profile trailers like RV's or enclosed cargo trailers where there is alot of surface area for cross-winds and the wind from passing trucks to act on the trailer and cause it to want to sway behind the truck.
For a better explanation of how weight distribution and sway control work and to see pics of these type of hitches, visit the Reese hitch website: www.reese-prod.com, or visit www.etrailer.com.
Old Apr 25, 2006 | 08:59 AM
osbornk's Avatar
osbornk
Avery good choice for a weight distributing hitch with built in sway control is the Equalizer Brand hitch. It is easier to install and use than the Reese and doesn't use chains. I bought mine from Rvwholesalers.com a couple of years ago for $399 delivered and I was able to install and adjust it in under an hour. Go to the website to see the hitch and get information on it. http://www.equalizerhitch.com/
Old Apr 25, 2006 | 06:41 PM
Ace!'s Avatar
Ace!
Perfect. Thank you both so much.
