Setting timing
Old Jun 2, 2019 | 10:51 AM
eric8's Avatar
eric8
Setting timing
My distributor on my 71 F100 302 has two separate vacuum nipples. One going to carb vacuum and the other going to a solenoid on the back of the manifold. Which one should be plugged for setting initial idle timing?
Old Jun 2, 2019 | 11:41 AM
Mach428's Avatar
Mach428
The one going to the carb but if the carb vacuum Port is above the throttle plates, there will likely not be vacuum going to it.
Old Jun 2, 2019 | 01:16 PM
Tedster9's Avatar
Tedster9
Disconnect and plug bofe of 'em at the carb and manifold and then it's not a factor. Set the idle RPM nice and slow while you do this, 500 - 600, so the centrifugal weights aren't pulling more timing in. A lot of people like a pretty fast idle, that's OK though not when actually setting ignition timing, both mechanical and vacuum advance start to pull in just off idle and that will interfere with setting an accurate base ignition timing. Then spool it up and see where it tops out at, this is the important part.
Old Jun 3, 2019 | 08:19 AM
eric8's Avatar
eric8
Thanks guys
67f100-390
Feb 24, 2011 09:55 PM
The_SnowMan710
34
Dec 29, 2010 04:01 PM
gfw1985
May 27, 2008 08:57 AM
jeremyd72
Aug 30, 2007 10:20 AM
PROSTOCK
29
Dec 19, 2005 12:45 PM
