Sponsored by: Real Truck
Trans upgrade
Old May 30, 2019 | 09:23 PM
Jb4trucks's Avatar
Jb4trucks
Trans upgrade
Looking at a 2003 E450 7.3 with 4r100 trans
Will the 5R series work behind the 7.3?
What would have to change?
Old May 30, 2019 | 11:11 PM
jetjockey99's Avatar
jetjockey99
you would need a stand alone trans controller to start with. It can be done but it would be cheaper to get a 4r built.
Old May 31, 2019 | 08:59 AM
Jb4trucks's Avatar
Jb4trucks
Thanks just exploring my options
Want to make sure I am doing what it possible to improve reliability and performance
Old May 31, 2019 | 02:21 PM
RenoHuskerDu's Avatar
RenoHuskerDu
The 4r100 can be built up real sturdy, there's lots of knowledge in the community by now. The 5r110 has weird gear ratios, only in town is it better than a 4r100. The 3rd and 4th in your 4r100 are exactly the same as 4th and 5th in the 5r110, so out on the open road there is no advantage to either. I'd say put a 6.0 tranny cooler on your rebuilt/beefed 4r100 and be a happy man.
To step up from the 4r100 you'd really need to go to the 6r140 found behind the 6.7 but nobody offers a standalone controller yet, afaik.
Here's a good site for info http://www.transmissiontuner.com
Old May 31, 2019 | 03:43 PM
beachcamperf250's Avatar
beachcamperf250
Look into the HD4R100 transmission.
Old May 31, 2019 | 04:34 PM
RenoHuskerDu
HD4R100 is all Ford sells now, afaik. It's steps in the right direction but misses a couple key mods like beefing the big center support, iirc. If that support wobbles it chews up the case so you don't even have a good core to trade in or rebuild.
A good shop can do a better job for less money, my opinion. But the Ford one comes with a Ford warranty. After you go in and beg for an hour they might honor it. Seriously the local Ford dealers give us grief almost every dam time we claim warranty.
Old May 31, 2019 | 06:44 PM
00t444e's Avatar
00t444e
A built 4r100 would be a better option and cheaper than the 5r110.
Old May 31, 2019 | 10:17 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
To put a 5R110W behind a 7.3L you'll need to get an adapter made. It was never made with a case that will bolt to a 7.3L. That's the cheap and easy part. I don't believe anybody makes a stand alone controller that works halfway decently with a 5R110W.
Here is an article I wrote about why it isn't going to heppen,
In the forums a question keeps appearing asking about the feasibility of swapping a later model transmission into an older truck. While it is possible, it sure isn’t practical. EVERYTHING is possible given enough time and money. If you have the time and money I can put ANY engine and transmission in ANY truck. I get to set the price and schedule, though. Oh, yeah, I don’t offer any warranty!
In the old days, before computer controls, if the trans would bolt to the engine it would work. If it wouldn’t bolt to the engine it wasn’t very hard to buy or make an adapter so that it would bolt up. While computers have made vehicles MUCH better (I’ll save the why that’s true for another article) it has made swapping engines and transmissions much, much harder.
Transmissions are now shifted by computer. The 5R110 wouldn’t be possible without computer controls. The shifting is too complicated for hydraulic controls.
The 4R100 is an all non-synchronous design. This means that for each upshift all that happens is a clutch is applied. All you need to do is control the pressure to the oncoming clutch and you're all set.
The TorqShift is MUCH more complicated. The 1-2 and 5-6 shifts are the same as the 4R100, they are non-synchronous and all you need to do is control the pressure of the OD clutch. The other shifts are the problem.
The 2-3 is a swap shift. This is a special category of difficult shift. I believe Ford was the last trans maker in the world to produce a swap shift transmission. Others have put swap shift transmissions in production and then replaced them within a few years. To make a swap shift the TorqShift needs to release the OD clutch to downshift the OD gearset while applying the intermediate clutch to upshift the Simpson planetary gearset. This is an upshift and a downshift occurring at the same time in the same trans. From my experience these two shifts MUST complete within 30 milliseconds of each other or it's going to feel awful. If the OD releases too soon the engine speed will flare. The amount of flare is dependent on how much sooner it completes. If it completes before the intermediate has enough capacity the trans goes back to first gear! Then it has to make a 1-3 shift. A few WOT 1-3 shifts means the trans comes out to replace the intermediate clutch. Been there, done that. If the OD releases after the intermediate comes on you end up in 4th gear (1.09:1 ratio) then downshift back to third gear (1.54:1 ratio.) Either way it's really bad.
Now if you made it through that you need to make a 3-5 shift. 4th gear is the 1.09:1 ratio that is only used in special circumstances. The 3-5 is a synchronous shift. It's timing requirements are about the same as the swap shift, but there is no downshift. To make the shift the intermediate clutch has to release while the direct clutch applies. If the intermediate releases too soon you get an engine speed flare. If the intermediate releases too late you get a tie up. A tie up is when all three pieces of the planetary gear set are held from turning. This means the output shaft of the trans STOPS. That's not a pleasant thing to have happen when you have the go pedal on the floor making a 3-5 shift. You can lock the wheels on an upshift! I've done this, too. You can also break expen$ive parts doing a tie up. Been there, done that, too.
Now start thinking of the combination shifts that can happen. How about cruising at 55 MPH behind some slow poke on a two lane road? A passing zone opens and you floor it. Now you may want to go from 6th to 3rd gear. You need to release both the overdrive and direct clutches and apply the intermediate. That's a synchronous shift in reverse.
As you can see from just these few examples it isn't a trivial task to make one of these transmissions shift. It's what I did at Ford for quite a few years, three of them working on the TorqShift. I'd be really surprised if anyone makes a controller for the TorqShift that works really well. I think someone could make one that does some basic shifting, but getting one so that it shifts at least as well as a stock trans is going to be a HUGE task.
Old Jun 1, 2019 | 11:49 AM
RenoHuskerDu
Originally Posted by Mark Kovalsky
SNIP
SNIP
Interesting. Like Steve Martin said, it's all about the ....... TIMING. eh?
Just the same, we've only ever had to replace three 5R110s that we remember at all in years. I'm driving one of those trucks. The PO had finance issues and neglected maintenance. The fluid was burnt and shifting got funky. Off to the core pile and a good used one went in my truck.
Old Jun 2, 2019 | 11:45 PM
darkjedi351's Avatar
darkjedi351
https://www.youtube.com/watch?v=3ZcicmEI9FY
I have over 200K on a 2000 ccsb that's been run rough with big tires, 4.30 stock gears and now with a 4.88 gears and 37's but I manual shift the crap out of it since I installed a center console and sidewinder shifter. the 4r100 will last if you take care of it
Old Jun 3, 2019 | 08:20 AM
RenoHuskerDu
Do you monitor ATF temps? Are you on synthetic ATF? That's good life from a stock 4R100. The lower axle gears actually mean less load on the tranny. All the trucks we see around here are mostly 3.73 diffs.
Old Jun 5, 2019 | 12:11 AM
darkjedi351
I added a trans temp gauge last fall and have had mobil 1 synthetic in it for about 2 years (20k miles). yea, I've been lucky. I've seen a couple of my buddy's 4r100's puke fluid all over while backing up with a trailer while I was able to tow the same trailer without incident. I did add a radiator with trans cooler and the larger 6.0 cooler when I switched over to mobl 1. I'm sure the factory 4.30's helped even with 36's
crazymut
19
Dec 1, 2009 01:26 AM
pupsford
Sep 19, 2008 09:21 AM
fhartell
Jan 16, 2006 04:22 PM
r0cky
Jun 7, 2004 07:51 PM
